Hammermill attachment
/ Hammermill attachment #1
Donman
Western Michigan
Yanmar 187D Bobcat 743 skid loader w/forks and homebuilt 6-way grader blade
I am thinking of making my hammermill an attachment to my Yanmar instead of using it as a stand alone unit. The unit is hard to horse around and bring to the locations I need to use it at. My thought was to fashon 3 point attachment points on the unit and hook it up to the pto which I can run at 1000 rpm. My biggest challenge is turning down the end of the shaft to 1 1/4 inch from 1 3/4 inch to accept my pto. One idea on how to do this was to use my angle grinder to rough it out close to diameter and then use a file or something to get it to finish specs. There is a pulley on the opposite side that could turn the shaft while working on it to keep it uniformly round. Any suggestions?
/ Hammermill attachment #2
You will loose the keyway doing that; I would purchase an adapter.
Can you buy a new part for your PTO shaft u-joint (half of the universal joint) that will make it the right diameter?
/ Hammermill attachment #3
Sounds like something I'd do...If I had a hammer mill.
You could do the grinder thing, but it would go best if you do two things.
1. Figure out a way to slowly drive the mill from the top side.
2. Make a jig to hold the grinder.
You'd lose the keyway, but that wouldn't matter if you were able to drill a hole for the sheer pin.
Before you start, do you have the correct rotation? (same rotation as your PTO) Or does it matter?
Also, taking 1/2" of material is quite a lot. Couldn't you find a drive yolk with a 1 3/4" bore? You'd still need to drill a hole for the sheer pin.
You could also take the part out and take it to a machinist, but I think it would be cheaper to but a new pto yoke.
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2023 Kubota SVL97-2 Compact Track Loader (A63118)
2023 Kubota...
2023 John Deere 6120M Tractor (A63109)
2023 John Deere...
Giyi 32" Rake (A62183)
2020 DRAGON ESP 150BBL ALUMINUM (A63569)
2020 DRAGON ESP...
2011 Chevrolet Express (A62180)
2011 Chevrolet...
