Hammermill attachment
/ Hammermill attachment #1
Donman
Western Michigan
Yanmar 187D Bobcat 743 skid loader w/forks and homebuilt 6-way grader blade
I am thinking of making my hammermill an attachment to my Yanmar instead of using it as a stand alone unit. The unit is hard to horse around and bring to the locations I need to use it at. My thought was to fashon 3 point attachment points on the unit and hook it up to the pto which I can run at 1000 rpm. My biggest challenge is turning down the end of the shaft to 1 1/4 inch from 1 3/4 inch to accept my pto. One idea on how to do this was to use my angle grinder to rough it out close to diameter and then use a file or something to get it to finish specs. There is a pulley on the opposite side that could turn the shaft while working on it to keep it uniformly round. Any suggestions?
/ Hammermill attachment #2
You will loose the keyway doing that; I would purchase an adapter.
Can you buy a new part for your PTO shaft u-joint (half of the universal joint) that will make it the right diameter?
/ Hammermill attachment #3
Sounds like something I'd do...If I had a hammer mill.
You could do the grinder thing, but it would go best if you do two things.
1. Figure out a way to slowly drive the mill from the top side.
2. Make a jig to hold the grinder.
You'd lose the keyway, but that wouldn't matter if you were able to drill a hole for the sheer pin.
Before you start, do you have the correct rotation? (same rotation as your PTO) Or does it matter?
Also, taking 1/2" of material is quite a lot. Couldn't you find a drive yolk with a 1 3/4" bore? You'd still need to drill a hole for the sheer pin.
You could also take the part out and take it to a machinist, but I think it would be cheaper to but a new pto yoke.
2022 FORD TRANSIT 250 CARGO VAN (A59905)
2022 FORD TRANSIT...
EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
EZ-GO SHUTTLE 2X2...
John Deere Loader Frames (A63116)
John Deere Loader...
2016 DRAGON 150 BBL VACUUM TRAILER (INOPERABLE) (A63569)
2016 DRAGON 150...
2009 Chevrolet 3500 Service Truck (A63116)
2009 Chevrolet...
2015 DODGE DURANGO RT SUV (A59575)
2015 DODGE DURANGO...
