Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #4,641
I was told it's the law that cans must be filled while on the ground. I tried filling cans while they were in the back of my truck only one time, and the station cut the pump off immediately and wouldn't turn it on until I placed the cans on the ground. I'm not sure how that carrier would be interpreted though.
That's been my understanding as well, although I doubt all station attendants are as vigilant. As for grounding, I'm not seeing how they would be any better grounded in a rack attached to the frame than in a truck bed that's bolted to the frame, and that evidently doesn't fly.
   / Harbor Freight Tools that don't suck #4,642
Cans on the ground are "grounded" lessening the electrical potential. Cans on a vehicle are isolated by the tires. Fuel moving through the hose creates a large static charge. The nozzle, when in contact with the vehicle while refueling creates a bond which equalizes the electrical potential as I understand it.
   / Harbor Freight Tools that don't suck #4,643
Bought a 5hp horizontal shaft gasoline engine for $99 to replace an ancient B&S on an ancient rototiller. Bolted right on and have Been using it for 3 years without a problem.
   / Harbor Freight Tools that don't suck #4,644
impact sockets - do you label them?
I use a lot of HF's impact sockets - but I consider them a pain at times because it's almost impossible to read the sizes without a flashlight.
Has anyone figured out a good labeling method?
I was considering a sudsy wash and scrub over the actual number then tracing the number w/ some white paint. What paint would stick the best?
Any other ideas?
   / Harbor Freight Tools that don't suck #4,645
I would just use whiteout over the number area, then scrape the excess off with a razor blade.
Aaron Z
   / Harbor Freight Tools that don't suck #4,646
Re: impact sockets - do you label them?
HF's impact sockets ... Has anyone figured out a good labeling method?... What paint would stick the best?
The paint-pens like a junkyard uses to label parts will stick to anything. I think this one from Ace Hardware is what I have out in the barn.
I painted over the stamped sizes on those black impact sockets then rubbed off the excess with a rag. This leaves white paint in the indentations.
I also painted a white ring around the socket that I reach for most often, for lug nuts.
I've also used that white paint-pen to write 'SAE' and 'Metric' on two dogbone wrenches that look identical. The paint is still intact and those are chromed. I can't think of any better marking paint.
   / Harbor Freight Tools that don't suck #4,647
Aaron Z
THANKS!
Once again the TBN borg pulls through with the answer immediately!
   / Harbor Freight Tools that don't suck #4,648
Great idea.
   / Harbor Freight Tools that don't suck #4,649
Been watching thread for awhile. I can not remember if anyone has bought the drywall lift. If anyone has bought one please give your thoughts.
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
golf cart (A55758)
golf cart (A55758)
5011 Ford F-550 (A55973)
5011 Ford F-550...
2009 Sterling Derrick Digger Truck (A55973)
2009 Sterling...
2014 Chevrolet Express 3500 Cargo Van (A55852)
2014 Chevrolet...
