Has anyone seen / know of a front mounted finish mower?
   / Has anyone seen / know of a front mounted finish mower? #11
   / Has anyone seen / know of a front mounted finish mower? #12
Yeah, I wasn't specific enough....
I have a power-trac 1850 with a front mounted mower (8 foot). Been thinking about getting the wife a real tractor and not her lawn tractor (well, like a MF 1715 or a BX(small) so).
Doing this does not resolve the finish mowing issue (she is in charge of the yard, I am in charge of the acerage). Thought maybe someone had come up with a mower that just attaches to the arms or push mounts on the front of a tractor. Honestly really not sure why this is not just a standard implement. Never understood the belly mount mower. Seems like a design that people just can't shake.
Ah, I was thinking of one for your PT. I would look for a Toro Groundsmaster (like: Toro Groundskeeper 345 mower ) or a similar front mount zero turn (Kubota, Deere, Grasshopper and Woods also make them).
A BX is too slow IMO and will beat you up on rough ground.
Aaron Z
   / Has anyone seen / know of a front mounted finish mower? #13
Lastec makes a nice big one that is a flex/sectional deck (to reduce scalping): Out Front Mowers
If you are talking about the one that mounts on a tractor, it's called "out front" but it looks to me like it mounts in the rear on the 3-point hitch. It says it takes a cat 1 3-point hitch and that looks like a rather standard PTO connection. However the caster wheels in the photo are all turned as if it were to run before the tractor. Are you supposed to drive in reverse???
   / Has anyone seen / know of a front mounted finish mower? #14
Aaron Z
No, when you click the link they call it "621EF - 126" Cut Articulating Mower"
These are out front mowers, with rear wheel steer:
$14K? Hmph... that ain't gonna happen.... Get myself a ZTR and a tractor and someone to come once a week and do her job for that money.
   / Has anyone seen / know of a front mounted finish mower? #16
I thought they made a finish mower for the 1850. Its on their price sheet as a 72" finish mower for $4k. Is it not a real finish mower?
http://power-trac.com/pdf15/SlopeMowerTSMprice010115.pdf
One thing about that large of a finish mower from PT is its a flat deck. It won't follow ground contours real well, and can scalp. I know because I have their 60" finish mower on my 425. Out land is almost table-top flat, so that's not a issue for me except by where our drive meets the road.
Simplicity makes some nice lawn tractors from $2500-$4500 range. How much lawn are we talking about here?
   / Has anyone seen / know of a front mounted finish mower? #17
That's too big of a mower deck for you... it about 10'. It requires 36hp from a shaft PTO, which I don't think your hydraulic PTO puts out. I recall someone taking a smaller lastec deck and adapting it to I believe a 400 series PT. I don't think the 400 series had enough oomph to run it.
   / Has anyone seen / know of a front mounted finish mower? #19
Not sure if your into searching for older equipment, but Gravely used to have a front mount mower for their 4 wheel tractors. This was back in the 80's? but they were built like a tank.
   / Has anyone seen / know of a front mounted finish mower? #20
Its for a machine with a front mount 3 point hitch.
Aaron Z
2019 PJ  40FT GOOSENECK TRAILER (A58214)
2019 PJ 40FT...
12ft x 8ft Military Flat Bed (A57454)
12ft x 8ft...
ALLMETAL MOBILE PRESSURE WASHER (A58214)
ALLMETAL MOBILE...
2017 Ford F-550 (A55973)
2017 Ford F-550...
2025 J & C Suppliers Enclosed Trailer (A56859)
2025 J & C...
Mini Skid-Steer Hydraulic Side Shifting Forks (New/Unused) (A59225)
Mini Skid-Steer...
