Haul tractor on dump trailer?
   / Haul tractor on dump trailer?
Here is one of my customers...
Well Wallace, that picture is worth a thousand words right there. That even looks like my tractor except for a little different BH. Can you tell me what length and width trailer that is? It doesn't look very big. Maybe I can get by with a smaller rig than I thought. I see the bucket is hanging over the front so obviously there is no problem doing that. I appreciate the help.
Is there a bucket attached to that loader? Sure looks like it would severely limit turning if there is one attached.
Interesting question. I didn't think about that. I'll bet there is no bucket attached. I think it would be visible by the right front corner of the trailer.
   / Haul tractor on dump trailer? #13
Belmont makes a really nice trailer. I'd love to get one.
One thing a (4x4) dump truck will do better than a trailer is manuever better, and go through serious mud better (if it's a 4x4). I see guys trying to back dumptrailers through the mud and even with 4x4, the truck doesn't want to do it if it's a heavy trailer.
Saw a guy a few years back burn up reverse in a tranny in an F-350 while trying to back a dump trailer though a long stretch of mud to a dirt pile.
Trailer/truck combinations are also more space consuming to store than dumptrucks.
All that said, for most of you guys, a dumptrailer is without question the best choice especially if you already own a pickup.
   / Haul tractor on dump trailer? #14
LBrown59 said:
1*but couldn't you also haul a few ton on the trailer?
Once you put a few ton in the back of a 1-ton dump truck you are already at your maximum GVWR and cannot legally tow a loaded trailer as well.
LBrown59 said:
2*Wouldn't a flat bed help on that so you don't have to load /unload over the side ?
Flat beds are useless when it comes to hauling loose loads such as gravel and loam so it may be easier to load but impossible to haul.
LBrown59 said:
==Why sell the 1 ton and get another 1 ton?
My 1-ton is a 94 F-350 Dump truck, I want a 1-ton pickup truck without a dump body.
LBrown59 said:
3*Why swap the 1/2 ton for a 1 ton when you all ready have a 1 ton?
Wouldn't it be simpler and less expensive to just sell the 1/2 ton and tow the trailer with the one ton you have now ?
See above, the 1-ton is old and not a good daily driver.
LBrown59 said:
4*How would getting another 1 ton make it a better daily driver than the one ton you now have?
Once again, the new 1-ton would NOT be a dump truck. Daily driving a dump truck is not very fun.
LBrown59 said:
5* If that's true how can swapping the 1/2 ton for a 1 ton give you a better daily drive then than the 1 ton you currently own?
See above. I feel like I am answering the same question 4 times...
It's nice to be able to just unhook a trailer and have a good light easy driving truck that gets 20+mpg and can easily sit 5 or 6 people as opposed to a heavy dump truck getting 16-17mpg on a good day and only seating 3 people unless you get a much heavier much more expensive 4-door dump truck.
   / Haul tractor on dump trailer? #15
It's a 6'8"x12' 10k
There is a bucket on it and the reason you don't see it is because it is only 60" wide
   / Haul tractor on dump trailer? #16
With the purchase of any trailer make sure you know the empty weight and subtract that from the GVWR, this gives you the payload. Most 16' dump trailers weigh about 4,000-5,000# so do the math.
On a side note. A heavier trailer does not equal better. Its like a bridge and must be constructed smartly.
Chris
My 16' GN dump weighs a hair over 9k, it's a duall tandem though.
   / Haul tractor on dump trailer? #17
1*Once you put a few ton in the back of a 1-ton dump truck you are already at your maximum GVWR and cannot legally tow a loaded trailer as well.
2*Flat beds are useless when it comes to hauling loose loads such as gravel and loam so it may be easier to load but impossible to haul.
3*My 1-ton is a 94 F-350 Dump truck, I want a 1-ton pickup truck without a dump body.
4*Once again, the new 1-ton would NOT be a dump truck.
5*Daily driving a dump truck is not very fun.
See above.
6*I feel like I am answering the same question 4 times...
7*It's nice to be able to just unhook a trailer and have a good light easy driving truck as opposed to a heavy dump truck
1*I thought Towing Capacity and Pay Load were 2 difference things and could be used independently .
I didn't realize it was an either or situation.
2*Why not side boards in that case.
3*I'd like a 1 ton pick up but I don't want nothing to do with having to shovel gravel dirt etc off it .
The problem with a pick up style bed is it's to high to load from the sides with my BX23
and like you I don't want a dump truck bed.
A bed that dumped but didn't have sides would be ideal in my situation.
4*That's why I first considered A Dump bed Pick up because I really do not need a full fledged dump truck.
But then the high sides presented a loading problem for my BX23 hence the decision to go with a flat bed.
5* I agree but I have Toyota Nissan and Doge D50 pick ups for daily drivers;so would not be daily driving a 1 ton.
6*That's casuse I can be dense when I wanna be.:D
Remember I said it not you!;)
7*I couldn't agree with you more on this point.
   / Haul tractor on dump trailer? #18
I agree with all your reasoning for swapping the dump truck for dump trailer, though I don't know where you found a dump truck getting 17 MPG :)
When I first got my 6x10 5 ton dump trailer I went to the quarry to see if I could get a tag from them that lets me buy from there, they don't allow pick ups or home made trailers. Was worried they might not allow this type of trailer, the guy at the scale house said they prefer this type of transport over a one ton landscapers truck with an over sized dump body, where the owner thinks he can fill it to the gunnel's with process road base.
I drive right in there now like I own the place, show the loader operator 4 fingers and drive out with 4 tons of product, which is not that big a pile in a 6x10 bed. Of course the trailer weighs more than a ton but with the substantial amount of weight on the tongue, I'm legal.
I'd get a 6 ton now as it's easy to overload, and wouldn't get anything less than a 12 footer, especially for OP's intent to hall tractor.
This pic is of 4.5 tons of wet process, I was probablly over a little on this load. doesn't look like much though.
JB.
   / Haul tractor on dump trailer? #19
I drive right in there now like I own the place, show the driver 4 fingers and drive out with 4 tons of product, which is not that big a pile in a 6x10 bed. Of course the trailer weighs more than a ton but with the substantial amount of weight on the tongue, I'm legal.
JB.
   / Haul tractor on dump trailer? #20
Well even my old 94 F-350 non-turbo IDI diesel dump truck gets 14-15mpg on the highway and I assumed the newer trucks would get at least 1-2mpg more. You know what they say about assuming though...:D
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 Haulotte 5533A (A53316)
2015 Haulotte...
(2) 12.4-24 TIRES W/ 8 LUG RIMS (A58374)
(2) 12.4-24 TIRES...
LOT: Assorted Pry Bars & Punches (A59076)
LOT: Assorted Pry...
BUSH & BOG 16 BLADE DISC HARROW (A52708)
BUSH & BOG 16...
