Hay bale comparison
   / Hay bale comparison
Ha ha ha ha! Around here it's about what you all are saying, 4x4 take about 400 to 500 lbs and 4 x 5 run about 900. Squares are usually 40lbs so the math is easy. Some guys bale really light or heavy but that would be a good average. I don't do hay but have lots of pals who do and they get 2 cuts, with the 2nd cut being about 40 percent the yeild of the first. Depends widely on what you're growing though and how you treat the field. Some dairy guys get 3 cuts of alfalfa every year but they fertilize a lot, reseed regularly and the last cut is way small compared to the first.
The big squares are coming into favor now, usually 800 to 900 lbs. I've never seen a bale handler system in action for small squares, sure would be neat to see.
[ame=http://www.youtube.com/watch?v=_KXHu9sTC2s]hay accumulator - YouTube[/ame]
You can have a video sent of this one in action. meanwhile, here's some pics: Hay Master, Inc.
   / Hay bale comparison #22
One other thing about round balers, they have variable chambers which bale tighter, normally more hay and fixed chamber.
Ground speed, windrow and tractor RPM and bale tension system are all variables to the amount of hay in a bale.
   / Hay bale comparison #23
I couldn't figure out how all you were getting 600-1100 lbs out of a 4x4 bale...then I realized you were talking round bales. Never done them myself. We do about 7 tons od 80 lb. 16 x 16 small squares and about 80 ton of 4'x4'x8' large square bales that come in around 1900lbs. On dry ground straight alfalfa, we get about a ton/acre. The grass on dry ground comes in about 1.5 tons/acre. We only get one good cut here on a dry farm in western Wyoming, if we're lucky a second cut but it's pretty skimpy. Local conditions vary greatly.
Bobcat MT85 (A60462)
UNUSED FUTURE FT-RP72 - 72" HYD ROCK CRUSHER (A52706)
UNUSED FUTURE...
yellow ball Trailer (A56859)
yellow ball...
2016 Ford Transit 350 Cargo Van (A59230)
2016 Ford Transit...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
