Help! 3 problems and just 11 hours in. Warranty? Insurance? Me?
   / Help! 3 problems and just 11 hours in. Warranty? Insurance? Me? #141
So do I. Going in a strait line, put a little pressure on the shifter and let it slide in smoothly. But I never do it when the wheels are spinning.
   / Help! 3 problems and just 11 hours in. Warranty? Insurance? Me? #142
Sorry, what I meant to ask is does it hurt to ENGAGE the MFWD while rolling?
Engaging while rolling is fine. Engaging while the rears are spinning, not so much.
Aaron Z
Aaron Z
I don't understand the difference between spinning and rolling?
   / Help! 3 problems and just 11 hours in. Warranty? Insurance? Me? #144
Was able to use the cutter for a while today. Everything seems to be in order with that. Much better with the tires set wider. I can see the benefit of the fender extensions, which I have yet to install.
One down note: I couldn't get it to come out of MFWD. The lever won't budge. I read the manual when I got home this afternoon and perused tbn. Can't see how I was doing anything wrong. I'm not too worried- will mess with it again tomorrow. Maybe something simple like a fuse, not pushing on clutch completely, or the wheels not being straight. Though it does beg the question, "where does correcting the quirks of a new vehicle end and the possibility of a lemon begin". Hate to think that way as I like so much about the tractor otherwise.
Not sure if its even close to being a 'lemon' yet.. Just because it took awhile to get back doesnt make it so..
   / Help! 3 problems and just 11 hours in. Warranty? Insurance? Me? #145
Roll the tractor, push clutch in, engage.. basically wheel turning, but tranny not.
   / Help! 3 problems and just 11 hours in. Warranty? Insurance? Me? #146
Difference between rolling and spinning...
Rolling is like normal driving and all 4 tires rotating the same.
Spinning is what happens to the back wheels when you are in 2wd and stuck. IE: rear tires going 90mph, and fronts not going at all. This is a bad time to engage 4wd.
But just drinking down the drive, and getting ready to pull off in the yard, engaging is fine. You don't need to stop.
Thanks that makes sense.
Btw, went to dealer this am and picked up the rear fender extensions and right hand door kit for $490. Ill hopefully get to do those Wednesday afternoon, so ill let you know how that goes.
While I was at the parts desk I got a wave from the manager and salesman but we didn't speak. No update on what is going to be covered from the work done last week.
No I don't think so either. Especially now that I understand the MFWD better. I'm just keeping it in perspective.
   / Help! 3 problems and just 11 hours in. Warranty? Insurance? Me? #149
Yep. Same for both the 4wd and the diff lock.
Aaron Z
   / Help! 3 problems and just 11 hours in. Warranty? Insurance? Me? #150
I operate the 4WD - engage and disengage - the same way. Moving slowly. Unless, I'm already stuck!! :laughing: Then, I have to shift while stopped..
AKfish
SOFTSTART W/ ACROSS LINE BY-PASS STARTER (A58374)
SOFTSTART W/...
2016 JLG 3248RS Electric Scissor Lift (A56857)
2016 JLG 3248RS...
2013 CATERPILLAR 336E L (A58216)
2013 CATERPILLAR...
QUALITY 102" X 50' CAR HAULER GOOSENECK TRL (A52708)
QUALITY 102" X 50'...
2013 Ford F-150 Pickup Truck (A56858)
2013 Ford F-150...
2017 Ford F-550 4x4 Cab and Chassis Truck (A56858)
2017 Ford F-550...
