Help! how the H** does this grease gun work?
   / Help! how the H** does this grease gun work? #11
Now that you have all solved the first problem (bleeding the air out of a new grease gun)let's attack the second problem with new grease guns. I'm talking about getting the darn tip off a grease zerk. it will very likely stick and put you through h*ll when you try to pull it off the zerk. Solution: loosen the tip by unscrewing the barrel (at tip).
They tend to go on easy and hold like heck when you try to take it off.
rimshot ( trying to take a proactive approach)
   / Help! how the H** does this grease gun work? #13
The best way that I have found to bleed the air is to warm the grease after a new tube is put in. TSC is notorious for having air pockets in the tubes of grease. That is why I don't not buy there anymore.
2018 PINSA 130BBL VACUUM TRAILER (A58214)
2018 PINSA 130BBL...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
Kubota M108S (A53317)
2012 FORD F450 XL SUPER DUTY TRUCK (A59823)
2012 FORD F450 XL...
