Help! how the H** does this grease gun work?
   / Help! how the H** does this grease gun work? #11
Now that you have all solved the first problem (bleeding the air out of a new grease gun)let's attack the second problem with new grease guns. I'm talking about getting the darn tip off a grease zerk. it will very likely stick and put you through h*ll when you try to pull it off the zerk. Solution: loosen the tip by unscrewing the barrel (at tip).
They tend to go on easy and hold like heck when you try to take it off.
rimshot ( trying to take a proactive approach)
   / Help! how the H** does this grease gun work? #13
The best way that I have found to bleed the air is to warm the grease after a new tube is put in. TSC is notorious for having air pockets in the tubes of grease. That is why I don't not buy there anymore.
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A56438)
1992 Talbert 70...
PALLET OF 15 4 X 8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4 X 8...
John Deere 50 (A60462)
1999 Featherlite Gooseneck Livestock Trailer (A59814)
1999 Featherlite...
3 Row Twin Row Renaldo Planter (A53317)
3 Row Twin Row...
LIMA MAC 60KW GENERATOR (A58214)
LIMA MAC 60KW...
