Help taking apart a tiller gear box
   / Help taking apart a tiller gear box #41
Glad to hear it.
   / Help taking apart a tiller gear box #42
HI, Thanks in advance to anyone who helps me out here.
I am trying to help a friend fix her Baltic tiller. It's a hoss, one of their biggest, six or even seven feet wide, weighs in close to 900 lbs.
The drive gear is broken off right at the face of the driving attachment faceplate.(where it comes out of the tiller, in other words.)
I want to replace the drive shaft, which I see in the Baltic manual has a bevel gear at the driving end with curved teeth.
I assume that part is available but likely very expensive.
Question: I read elsewhere in this forum a posting which seems to indicate that I can punch that drive out of the tiller gear box. Is this right?
The exploded drawing in the manual indicates that there are at least two taper bearings, several washers and stuff in that gear box.
Will I be able to punch that drive gear out or will I have to disasemble the entire driving attachment housing?
Thanks
WCC
   / Help taking apart a tiller gear box #43
Good work...
   / Help taking apart a tiller gear box #44
Thanks
WCC
Is a Baltic tiller the same as a BCS? Just never heard of one?
Cory
   / Help taking apart a tiller gear box #45
Thanks
WCC
Cory
WCC, I initiated this thread a couple years ago and the help from the guys here stepped me through everything. I was successful in getting the work done myself with all the advice here. I'm no expert on repairs such as this, but I can offer some advice to assist the folks trying to help you. If you can, provide info such as model # and if you can obtain and post some good pics of the equipment that will really help. That sounds like quite a monster tiller. The BCS I have is quite a machine and it's not their largest. Good luck with the project and it's nice of you to help a friend.
Coast
Skid Steer Tree Puller w/Hitch End (A49339)
Skid Steer Tree...
2019 John Deere 5075E (A47307)
2019 John Deere...
2021 Dodge Ram 2500 Promaster (A47307)
2021 Dodge Ram...
Deere 324E (A47307)
Deere 324E (A47307)
2014 (A46502)
2014 (A46502)
KC 45in. Mini Skid Steer 4 Bar Land Plane (A46502)
KC 45in. Mini Skid...
