mllud
- Joined
- Oct 4, 2019
- Messages
- 303
- Location
- Missourian
- Tractor
- Massey Ferguson / New Holland 3010/ Ford 3550 Backhoe
it is one of two "ears" on the lever that rotates with the clutch pedal and pushes the throwout bearing to disengage. So far, I have not found the part. What all should I replace while going in there. I understand the loader needs to be detached and the tractor split. Question is what would break off one of those cast iron "ears"?
It does take considerable force too disengage the clutch but its built for that.
The part pivots from two short shafts that go through the bellhousing. There is a bushing in the bellhousing. If the bushing is worn on the peddle side it may have allowed misalignment putting more pressure on that one of the two sides that push the throw out bearing.
I looked online and did find one that specified for A TO35. Used, I believe the part you need is in this link.
Massey Ferguson TO35 tractor transmission shifter shift fork w/ shaft | eBay
Check on Tractor by net to buy first.
When you replace it put in new bushings and those short shafts if needed. I think they interchange with later 35 models. Misalignment from wear in bushings may have broke it. I recently did this job on a 203
