Oil & Fuel Home heating oil = Diesel?
   / Home heating oil = Diesel? #11
In New England, #2 is home heating oil. I don't want to get back into the diesel vs home heating oil debate. Around here, there are too many different opinions... /forums/images/graemlins/grin.gif It works in my tractor and that is all that I care about.
   / Home heating oil = Diesel? #12
That's interesting. I lived in Morrisville, VT for a couple of years and all that was delivered to everyone I knew was #1. Hmmm, ?
When I go buy diesel for the BX, the pump at the gas station always says #2. Oh well, it works. A rose is just a rose, and by any other name, would still be a rose.
   / Home heating oil = Diesel? #13
If you had outside storage of the heating oil, they would use #1 for cold weather flow characteristics. My storage isn't exposed to the elements, so #2 works well. #1 is also referred to as kerosene many times. Numbers and names are used interchangeably by the dealers, but not always the same product. Example.... a red rose might also be a tangerine rose.... /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / Home heating oil = Diesel? #14
Yep, it was outside storage. The tank was underground, but the pipe from tank to house was exposed for a couple of feet.
Hope you finally got that bagger together.
   / Home heating oil = Diesel? #15
I buy my off-road diesel directly from a fuel distributor. They told me that off-road diesel is EXACTLY the same as home heating fuel with red dye added.
John
   / Home heating oil = Diesel? #16
You are completely correct. I am not disagreeing with you at all. I believe that we are saying the same thing. The only distinction is that there are two grades of the stuff.
#2 is what is typically used in both home heating and in diesel engines.
#1 is the same thing but with an anti-gelling agent added for extremely cold conditions. #1 is also used in both home heating and in diesel engines.
When I lived in VT, the fuel co. delivered #1 for my heater because I had an outside tank and it was rather cold in the Green Mtns. It makes sense that Junkman has #2 delivered for his heater as his tank is not exposed.
Likewise in VT, for my diesel VW Rabbit pickup, the local gas station sold #2 as diesel fuel for most of the year, but switched over to #1 during the coldest 10 or so weeks of winter. Where I live now, and even up in the Sierra Nevada, I have only seen #2 sold as diesel fuel.
   / Home heating oil = Diesel? #17
</font><font color="blue" class="small">( ........Hope you finally got that bagger together. )</font>
I am working on it slowly....... don't need to get it done until the leaves start to fall, but the wife doesn't agree. She keeps asking why I bought it...... I answer ...... so she has a reason to nag about something.
   / Home heating oil = Diesel? #18
Short answer = Yup. I am new to your forums but worked for a lubricants & fuel oil distributor for 10 years. Back then the oil co.'s sold you a couple of different products out of the same spigot and mixed in an 'additive package'. To be safe I'd mix an anti-gel conditioner in your heating oil tank if there is any left before the cold weather hits.
And yes, this issue has been kicked around ad-nauseum, the real fuel problem now is that you can't buy a decent gas / diesel storage can any more.
   / Home heating oil = Diesel? #19
</font><font color="blue" class="small">( While diesel fuel is the same as fuel oil, don't forget the distinction between #1 and #2. The diesel fuel used everywhere in summer and used throughout moderate climate areas in winter is #2. #1 is the same stuff but with an anti-gelling agent added. #1 is used as diesel in very cold climates in winter. Most all fuel oil is also #1 for obvious reasons. <font color="red"> I do not remember ever hearing of #2 being used as home heating fuel oil. )</font>
If it was warm enough to use #2 you wouldn't need to use the furnace as it would all ready be warm enough that you wouldn't need to heat the house.
   / Home heating oil = Diesel? #20
Hmmm...Did you read Junkman's post above? He uses #2 as fuel oil. BTW, he told me to ask you about your $5 license plate. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
KUHN SR110 GII LOT NUMBER 39 (A53084)
KUHN SR110 GII LOT...
2021 JOHN DEERE HX14 LOT NUMBER 14 (A53084)
2021 JOHN DEERE...
Deutz BF12L413F 19.1L V12 Turbo Diesel Generator (A51691)
Deutz BF12L413F...
434669 (A48836)
434669 (A48836)
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A53472)
2018 John Deere...
