Oil & Fuel Home heating oil = Diesel?
   / Home heating oil = Diesel? #31
Number 2 fuel oil is all I've ever used in my oil furnace. This year I switched to low sulfur B20 #2 for heating and my tractor. The company that delivers it said they do blend in #1 during January & February if needed to keep the gel point low enough for outside tanks. They also add anti-gelling to the #2 fuel for the winter months.
   / Home heating oil = Diesel? #32
Storage of Diesel--Can it go bad?
issues are water in fuel from condensation in a less-than-full tank, and algae ...solutions are water-block filter or other, and specially formulated algaecide for diesel fuel ...for really long term storage, diesel fuel can be "reconditioned", or "polished" ...pumped out, through a filter and back in ...like kidney dialysis?
   / Home heating oil = Diesel? #33
</font><font color="blue" class="small">( Home heating oil and off road diesel are the same exact thing in CT. )</font>
That's what the Ashland/Marathon bulk plant told me today.
   / Home heating oil = Diesel? #34
</font><font color="blue" class="small">( I purchased an electric fuel oil pump from Northern Equipment.
paul
)</font>*******I'm looking for one of these but not for 139 bucks at TS.
Could you give me an idea on prices?
   / Home heating oil = Diesel? #35
</font><font color="blue" class="small">( I was told by a heating a colling technicial... two actually, that home heating oil and diesel are the same. The only difference is the tax and the red dye. camp fires.
I am hesitant to put this in my tractor but if it really is the same I can use the stuff that I paid about $400 for.
Thanks )</font>
Diesel,home heating oil and fuel oil are all the same thing.
You could have been filling your tractor from the tank all along.
   / Home heating oil = Diesel? #36
</font><font color="blue" class="small">( Maybe you should set up the old furnace oil tank to be your new tractor fuel tank for the long term. The cost per gallon of delivered heating oil should be much less than the cost of road diesel. Cheaper for campfires and tractoring.
Set it up out of the sun with a filter/water seperator, pump (or gravity), and fill hose and you're in biz. )</font>
He could have been doing this all along!
   / Home heating oil = Diesel? #37
</font><font color="blue" class="small">( Actually I never had an oil furnace. I have a 50 gal drum in my shed, with the tractor, and I purchased an electric fuel oil pump from Northern Equipment. Has a 6' hose with nozzle and runs off of a 12 volt battery. Makes fueling up a quick and easy job. I also now have a diesel generator for backup power, so for that as well, I usually have lots of reserve fuel at the ready.
Around here heating oil runs 50-60 cents cheaper per gallon than <font color="red"> OTR </font> diesel.
paul
)</font>
<font color="red">is that On The Road or is it Off The Road? </font>
   / Home heating oil = Diesel? #38
</font><font color="blue" class="small">( Dan, you don't wanna use that stuff, I'll come take it off your hands. Just being a friend, please, don't thank me. /forums/images/graemlins/grin.gif )</font>
I'lll give him ten cents a gallon for it - sorry for out bidding you.
   / Home heating oil = Diesel? #39
</font><font color="blue" class="small">( Diesel,home heating oil and fuel oil are all the same thing.
You could have been filling your tractor from the tank all along. )</font>
NO, NO, NO.
For the umpteenth time, it all depends on where you are located and from where you supplier is purchasing his stock. For example, here in New Hampshire, I can get 3 distinctly different products that are labeled as off road. Also normal pump diesel is not usually home heating oil.
Bottom line is to ask you supplier. In your case they are the same, in my case they are not.
   / Home heating oil = Diesel? #40
</font><font color="blueclass=small">( Diesel,home heating oil and fuel oil are all the same thing.
NO, NO, NO.
)</font>[/color:"blueclass=small"]
They certainly ARE the same here! "AG" diesel ( off road diesel) and home heating oil...same product...dye and all. HIGHWAY diesel....no dye..and about 45 cents per gallon TAXES on it. Other than the "dye job"...STILL the same stuff.
But the bottom line is..ANYTHING you can burn in a home heating furnace will work fine in an off road diesel engine.
MTM CHORE MASTER 2400 PSI PRESSURE WASHER (A51248)
MTM CHORE MASTER...
(4) STEEL CARTS (A51248)
(4) STEEL CARTS...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51248)
(2) METAL SPOOLS...
2023 JACTO JATAO-1000 LOT NUMBER 66 (A53084)
2023 JACTO...
2005 Ford F-750 Crew Cab Heil 5 Yd Dump Truck (A51692)
2005 Ford F-750...
2002 HAYS SDBTH36SS KILLEBREW FERTILIZER TENDER TL (A51247)
2002 HAYS...
