Hooking up PTO w/ Engine Running
   / Hooking up PTO w/ Engine Running #21
I run the tractor to make the 3 pt connections. I shut it off to attach to the PTO. I am not in that big a hurry and I feel safer that way. I plan to enjoy my seat time, not hospital bed time.
   / Hooking up PTO w/ Engine Running #23
That is what I do and how all my employees' do it if they wan't to keep their job.
   / Hooking up PTO w/ Engine Running #24
My farm is on a hillside, so there are almost no level places to hook up. This dictates that I leave the tractor running to make the 3 pt connections, as adjustments will be made. Once the implement is attached, I always shut the engine off. Then, and only then, do I attach the PTO shaft. I play guitar and like my arms, hands and fingers. :thumbsup:
Joe
   / Hooking up PTO w/ Engine Running #25
I like to keep myself in one piece, so the engine is off any time I could touch a PTO or something driven by one. I hook up the 3ph implements with the engine on, but shut it off for PTO hookup.
Aaron Z
   / Hooking up PTO w/ Engine Running #26
The BX2230 and my L3130 will allow the rear PTO to operate without the operator in the seat if it is tilted forward.
David Kb7uns
The parking brake has to be set on the JD2520 and the gearbox has to be in neutral for the PTO to operate without the operator.
   / Hooking up PTO w/ Engine Running #27
Depends on the tractor. Our larger tractors have PTO brakes that are engaged when ever the engine is running. In order to turn the PTO to get it lined up you must shut off the tractor. I generally shut off any tractor when hooking up the PTO, but some I'll do with it running. Something like my Ford NAA with the manually engaged transmission driven PTO is VERY unlikely to start by itself, almost impossible I'd say. Now something with a hydraulically engaged PTO there is a chance if hydraulic pressure is lost it could start by itself. Those are also the tractors with PTO brakes often, so I just shut them off.
My2320 is electro-hydraulic. I have to put the PTO mode lever to mid only to turn the pto shaft. I am guessing the pto brake is ahead of the mode selector so the brake works on all modes. I have also seen tractors that would have the pto turning with it disengaged and the engine running(warped clutches?) I really don't want to find out how warped they are with my hands!
   / Hooking up PTO w/ Engine Running #28
I definitely turn off my tractor.
   / Hooking up PTO w/ Engine Running #29
Now, I routinely run the pto when augering grain, without me in the seat. I need to be outside of the tractor watching the auger and making sure the grain is flowing properly.
I believe that's something that smaller tractors can't do without bypassing the interlock....
Most (not all) small Deeres have an offseat PTO capability, so no bypassing the interlock. As far as other CUTs...can't answer.
As far as hooking up the engine running...no, I don't.
   / Hooking up PTO w/ Engine Running #30
Kubotas do (or at least our L3830 does).
Never used the rear PTO on the BX2660 so cannot say for that one and the B7500 doesn't have any operator presence shutoff mechanisms.
Aaron Z
2021 XCMG CV123PDU ROLLER (A60429)
2021 XCMG CV123PDU...
2018 INTERNATIONAL 4300 NON CDL 26FT BOX TRUCK (A59904)
2018 INTERNATIONAL...
Dayton 32965 80-Gallon Horizontal Air Compressor, 22 Volts, 5 HP, 2 Stage, 3 Phase (A59076)
Dayton 32965...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
2022 KOMATSU D71PXI-24 CRAWLER DOZER (A60429)
2022 KOMATSU...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A56436)
2023 New Holland...
