How do I raise the 3ph higher?
   / How do I raise the 3ph higher? #11
SKUNKWERX
That is really sweet looking rig.
   / How do I raise the 3ph higher? #12
SkunkWerX said:
That is a good idea, if you take proper measurements you may still be able to spin the blade 360, depending on how far below it's pins the top of the blade is.
RedDirt, on my BX2350 I can lift my RGB a good 18 inches off the ground, so I am having trouble picturing why you cannot? Is it simply too large of a Blade? Mine is standard CAT1, from about 20 years ago, and it was a 6 footer before i cut it down to 5 feet.
Try to shorten your toplink as much as possible. If not, get a shorter one.
(even thought the BX toplink is among the shortest).
Only other thing I can think of is that the "A" frame on the blade is very tall (height from lower pins to toplink hole). If this is the case, maybe there is a way to fabricate a lower toplink hole?
Check this pic:
RearBlade on BX2350
Skunk,
It is a little difficult to see from this photo because the blade is reversed and angled for pushing snow but bottom of blade is only 7 1/2" from ground when fully raised. My lower pin to top link pin measurement is 17 1/2". What does your measure? The blade is 5ft wide.
I can shorten the top link about 2 inches and gain blade height but then, like Racer, the cutting edge angle of attack changes to more of a scraping (when pulling) rather than cutting angle.
Right now my top link length is set so when the blade is lowered to the ground the top and bottom edges of the blade form a plumb line. At this setting the horizontal bar (side link to blade pivot) is at a slight uphill angle to the rear. As I see it, this horizontal angle would be best if it were actually level . Then rotation of the blade would not change the transverse (?) angle of the blade. (The more the pivot tilts (from fore/aft plumb) the more the sideways angle changes when you rotate the blade.)
To me, all this geometry means is that my blade was meant to be mounted on a tractor with a higher 3PH. The only apparent fix may be something similar to the Carter Quick Hitch that raises the lower pin connection on the tractor. As wushaw noted, you'd not be able to rotate 360 without disconnecting but, unlike my idea of lowering the pin connection on the implement, the blade could indeed be rotated.
   / How do I raise the 3ph higher? #13
First I am a lightweight tractor user with 300hrs on my first tractor experience.
OK, my tractor is a bit larger (L3430) but I am still curious about this problem.
On my tractor the top link seems to have the most effect on lifted or transit height. I have three vertical choices on the rear of the tractor for attaching the top link. The lowest point to connect the top link will give the attachment the greatest lift when fully raised. I assume this is due to the geometry of the lift arms in relation to the top link's anchor point.
So, seeing that your tractor seems to only have one mounting point at the tractor side for the top link, is there any way to safely fabricate a lower connection point (at least for testing the idea?)
If the more experienced see a flaw in my thinking, so be it...
Good luck!!
   / How do I raise the 3ph higher? #14
I believe the A-frame is too tall.
If your toplink attached lower in the A-frame you would still be able to adjust the proper cutting angle when the blade is down but the geometry change when lifted would give you much more height.
I had simular issues with a cat0 3pt tractor when I adapted a cat1 rear blade. I ended up lowering the top link holes about 3 inch's in the A-frame and it made a world of differnce.
Regrds,
Mundy
   / How do I raise the 3ph higher? #15
Mundy said what I was thinking in my last post.
RedDirt, my blade is a few acres away, but I'll go down there this eve and take a measure for you. I am guessing the A frame on mine is shorter by the looks of it.
You may very well be right, that blade might be engineered for a Taller Tractor? Though, as a 5 foot blade, you wouldn't think it would be meant for "huge" tractor?
This may be the difference between a blade made for a full size Ag-style tractor vs. a compact???
I'll get back to you this eve with a measurement.
****edit: back with the measurement, it is 17", maybe 17.5" center of bottom pins, to center of toplink hole.
OK, this is weird. My blade is at a normal cutting angle when scraping the surface.
Now are we looking at blade geometry??
   / How do I raise the 3ph higher? #16
You are correct. we are not looking at blade geometry. We are looking at 3pt lift Geometry.
A change to 3pt geometry can achieve the same blade cutting/scraping angle in the down position but provide a higher amount of implement rotation during lift and result in the blade being higher in the up position.
Regards,
Mundy
Good feedback guys. Keep it coming.
   / How do I raise the 3ph higher? #18
Regards,
Mundy
Mundy,
Thanks for the observation, and I agree, generally, but how so here? SkunkWerXs and I have very similar tractors. Presuming our side links are the same length and the distance between the lower arms and top link is the same (vertical at the tractor end) and the side link to top link dimension is within 1/2" (vertical at the implement), how can he have an 18" lift and I have only 7 1/2"? The only variable is the top link length and this is what changes the cutting angle.
Skunk,
Thanks for the measurement. Tomorrow I'll pull the bx23 out of the shop and get a better side photo for an easier comparison to you photo. Our blades look VERY similar.
I was in the process of trying to jury rig a lower top link connection for trail when "work" called...then after work the power went down.
   / How do I raise the 3ph higher? #19
Yes, top link length is the key. I am not talking about any measures or attachment points on the tractor. Some tractors are adjustable here. I Have assumed yours is not. I am talking about distance between lift arms and top link at the pins and hole in the A-frame of the implement.
A 1/2" vertical at the implement will change the top link length and make a big differnce 5' out at the blade. I don't know about 10 1/2" differnce but it is possible.
Compair the measures he gave with yours including top link length and let us know how close they are.
Mundy
   / How do I raise the 3ph higher? #20
A few things I just noticed when compairing your photos. The 2 blades A-frames are very differnt. Yours has the lift pins closer to the tractor than the toplink hole. SkunkWerx blade they are the same distance from the tractor. This by desing makes his toplink shorter and provides him with more rotation and lift. And if his top link hole is 1/2" lower that provides an even shorter toplink.
Regards,
Mundy
(4) CAMARO 5 LUG WHEELS & 245/50R16 97H TIRES (A54757)
(4) CAMARO 5 LUG...
2025 BrushFox XHD-78HF 78in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
Enmark Z Spray (A53316)
Enmark Z Spray...
ASSET DESCRIPTIONS & CONDITION (A57880)
ASSET DESCRIPTIONS...
2023 HELI CPYD25C FORKLIFT (A58214)
2023 HELI CPYD25C...
Zero Turn Mower (A55853)
Zero Turn Mower...
