Henro
Elite Member
- Joined
- Jul 4, 2003
- Messages
- 4,982
- Location
- Few miles north of Pgh, PA
- Tractor
- Kubota B2910, BX2200, KX41-2V mini EX
<font color="blue">In the original post Junkman said he was using a closed center valve. Since fluid does not flow thru the valve when the spool is in neutral, a closed center valve will work in this application when teed into the loader lines. </font>
MadRef,
The thing that puzzles me is that since the closed center valve is tied into an open center system, I wonder where the pressure is coming from to activate anything tied to the closed center control valve. Since the open center system develops little or no pressure in the loop until one of the open center control valves is operated. At that point pressure is developed between the pump and the activated control valve as you know.
Junkman, are you able to activate the grapple [I saw the other thread on your grapple (again, forgot about it)after posting to this one today] when your loader control valve is in the neutral position?
It just seems to me that hooking up like this could introduce a lot of variability into the operation of whatever is connected to the closed center control valve. I could be all wet here. I am just asking because I am curious.
What I would expect to see happen, IF the closed center control valve is hooked between the hose on the inlet side of the loader valve and the return to tank hose, is that when the loader valve is centered there would be very little pressure to close or open the grapple (again, I assume it is controlling the grapple). BUT if the loader valve was operated, then the pressure available to the grapple cylinder would increase, relative to the load felt by the loader cylinders being operated. Up to the point where a PRV tripped.
I guess what I am really wondering is if Junkman's original question related to adjusting system pressure might relate to having a closed center valve TEEd into his open center system?
It sure looks to me like with a closed center valve TEEd into the open centered system, the pressure available to Junkmans closed center control valve could vary anywhere between very little and up to maximum system pressure, depending upon what was going on with his loader at the time.
Appreciate your comments on this!
MadRef,
