Oil & Fuel How do you fuel your TC30?
   / How do you fuel your TC30?
I'm sure I will be with funnel and can from time to time. Best buy two and keep one in the truck. /forums/images/graemlins/grin.gif
   / How do you fuel your TC30? #12
<font color="blue"> Some kind of storage tank would be good, but I just don't use enough. </font>
*** <font color="red">****************** </font> ***
<font color="brown"> You don't need to use a lot of fuel to take advantage of some sort of fuel station / storage tank.
One of the greatest benefits of such a set up is easier filling and handling of the fuel regardless of how much or how little diesel fuel you use.
</font>
   / How do you fuel your TC30? #13
<font color="red">1* A tab on the collar sticks out and you use the side of the opening to push the collar down. </font>
1*Which n=means you can't use MR. FUNNEL with them right!
   / How do you fuel your TC30? #14
</font><font color="blue" class="small">( With all the posts that concern bad fuel I purchased Mr. Funnel. Check it out at the following;
http://www.mrfunnel.com/Home.html
It works great. To test it you add water! yes water;; none will run through the funnel. Yes it is pricey, but considering cost of an injector pump or an injector it is like changing oil on schedule. Would you add a little dirt with your oil? You will be surprised what is left in the Mr. Funnel after filling your fuel tank. I use it all the time even when tractor is on trailer and I fill at service station, I fill through the Mr. Funnel and will find debris even right from the fuel station pump. )</font>
MR Funnel and spill proof can's don't go together.
   / How do you fuel your TC30? #15
HRS, I bought a kerosene pump from Home Depot 3 years ago for under $10.00. It uses 2 D batteries and will pump all but 4 or 5 ounces from a 5 gallon can. Bill C
   / How do you fuel your TC30? #16
Since I have a diesel pickup as well, I bought a standalone 275 gallon oil tank from the local heating supply company, and installed a 110V AC diesel pump with a standard fuel nozzle (similar to what they have at a gas station) ordered online from Northern Tool. No more mess, and no more hefting a jerry can. Getting bulk fuel delivered is cheaper as well, not including the tax break because it's a business expense.
I do wish I'd spent a couple more dollars for an auto-shutoff nozzle and a flow meter.
Will look into it. Thanks.
Sounds very useful. I probably will not run out more than a tank per outing, so something working on around 5 maybe 10 gallon capacity would be best for my needs. I've yet to make it up to TSC.
   / How do you fuel your TC30? #19
</font><font color="blue" class="small">( Sounds very useful. I probably will not run out more than a tank per outing, so something working on around 5 maybe 10 gallon capacity would be best for my needs. I've yet to make it up to TSC. )</font> web page FUEL STATION
Very informative. Thanks.
Giyi 72" Box Broom Sweeper (A57149)
Giyi 72" Box Broom...
Giyi Mini Auger (A57149)
Giyi Mini Auger...
2012 Ford Explorer Limited (A57148)
2012 Ford Explorer...
2302 (A58376)
2302 (A58376)
Honda Pioneer 700 4x4 Utility Cart (A56857)
Honda Pioneer 700...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
