How do you set the polarity when you have a generator and the battery is a positive g
   / How do you set the polarity when you have a generator and the battery is a positive g #1
feleds
Lisbon, Ohio
1953 Farmall super c
I知 having trouble with my battery and I知 told I need to set polarity. How do you do that. I have a positive ground
   / How do you set the polarity when you have a generator and the battery is a positive g #2
Make a jumper wire 14 or 16 gauge long enough to reach from the battery to the generator. Put alligator clips on both ends. To polarize a generator on a tractor having a Delco 6 V positive ground system attach one clip to the “A” terminal on the generator. With the other clip briefly, for only a split second, tap the negative terminal on the battery. This will match your generator polarity to that of the voltage regulator.
Thanks that was very clear.
1998 PETERBILT 377 MIDROOF SLEEPER (A58214)
1998 PETERBILT 377...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A56436)
Case Wheels for...
2000 Sterling L9513 Winch Truck (A56438)
2000 Sterling...
2012 NORAM POWER SYSTEMS 100KW GENERATOR (A55745)
2012 NORAM POWER...
2003 Pierce 75ft Ladder Fire Rescue Truck (A55852)
2003 Pierce 75ft...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
