How do you set the polarity when you have a generator and the battery is a positive g
   / How do you set the polarity when you have a generator and the battery is a positive g #1
feleds
Lisbon, Ohio
1953 Farmall super c
I知 having trouble with my battery and I知 told I need to set polarity. How do you do that. I have a positive ground
   / How do you set the polarity when you have a generator and the battery is a positive g #2
Make a jumper wire 14 or 16 gauge long enough to reach from the battery to the generator. Put alligator clips on both ends. To polarize a generator on a tractor having a Delco 6 V positive ground system attach one clip to the “A” terminal on the generator. With the other clip briefly, for only a split second, tap the negative terminal on the battery. This will match your generator polarity to that of the voltage regulator.
Thanks that was very clear.
John Deere Gator (A53317)
John Deere Gator...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
Chevrolet 2500 Flat bed (A56436)
Chevrolet 2500...
2005 MACK TRI AXLE DUMP TRUCK (A52707)
2005 MACK TRI AXLE...
John Deere 204L ABSOLUTE SALE (A56436)
John Deere 204L...
SKID MOUNTED CONTAINMENT (A58214)
SKID MOUNTED...
