How do you store your attachments
/ How do you store your attachments #1
kycontrols
Bronze Member
Getting my first tractor along with a box blade and a rear blade. The tractor will fit fine in my current 20X24 'barn' but I am wondering about the attachments. I have already hinted to the wife about an expansion but someone has to have a ingenious idea on how to store attachments.
I rather not store them outside on the ground.
/ How do you store your attachments #2
My cutter and box blade are outside right now along with the tractor. Until I get my tractor shed built, I have by box blade and cutter sitting upon concrete blocks to keep them off of the ground.
/ How do you store your attachments #3
All outside. The amount of time it would take a boxblade to rust bad enough to not be useable.........doubt it will be my problem..
/ How do you store your attachments #4
I will be storing mine in a 3-sided livestock shelter.
/ How do you store your attachments #5
I store mine on pallets inside a fabric quonset-type building which my brother gave me.:) I keep the ends open to minimize condensation. In the meantime I'm building a storage building with a concrete floor.:)
/ How do you store your attachments #6
On pallets in a garage. I am planning to put casters on the pallets to make it easier to move the the snow blower and the BB
Pallets with casters is a neat idea!
/ How do you store your attachments #8
Not knowing where you live...but I've got a rock rake that has been outside for going on 9 years and still works fine...paint is a little dull, but big deal...
After 9 years of the same exterior exposure, my PHD just needs a little extra grease in the spring to make the PTO knuckle flexible...:D
A extra leanto would be nice but useable land is valuable...:rolleyes:
/ How do you store your attachments #9
Tractor and ballast box are in the garage. The ballast box is on a furniture dolly. Everything else is outside in a HOA mandated fenced in enclosure. The enclosure has 3/4" rock and each implement sits on three to four 12" square concrete paving blocks.
/ How do you store your attachments #10
I dunno, I got a pallet jack/dolly on sale at Harbor Freight for $149.
I can put the implement on a plain pallet, or on a pair of 4x4s, or anything else that holds it up off the ground. The jack stores under one of the implements.
And, it is good for anything else big & heavy.
I just line 'em up along the side of the garage. For me, this is the way to go as long as you have a concrete floor.
/ How do you store your attachments #12
I have all mine on furniture dollies. That way I can put the ones that are seasonal behind the ones I am going to use this season. It really makes hook up a lot easier also. I can also turn them odd ways to make them more compact for storage. I also nest them when possible, the water tank inside the pond scoop, on top off the pallet forks,etc.
/ How do you store your attachments #13
All but my back blade are in the basement of my carriage house. The back blade is on 1 by boards just behind.
All the other implements have castors or dollies underneath them or are sitting on a pallet with castors underneath. Helps a WHOLE LOT to be able to move the implement to get it both on and off. The boards work for the lightweight back blade.
Ralph
/ How do you store your attachments #14
outsides on old used tires to keep them off the ground....
ideally, a lean to would be nice
/ How do you store your attachments #15
There was a post on here a while back where someone built heavy duty shelving and placed implements verically on the shelving using a pallet fork attachment on the loader. It was very well done.
There are also stands for mowers and PHD. I plan to build a stand for my PHD under my leanto so that it takes up as little space as possible, yet is easy to put on and off the tractor.
I think the castered pallets are probably the most versitile. But, mine are on dirt or stone. So, I would want pneumatic casters. Now if I could just find an inexpensive source for them.
/ How do you store your attachments #16
I used to keep my ballast block on a furniture dolly. Got tired of lining it up when removing, so I took the casters off the furniture dolly and welded them to the bottom of the ballast box. Now it is fully mobile at the drop of the 3 point.
/ How do you store your attachments #18
Egon said:
A wood pallet and sky tarp seem to work fine for me.:D :D :D
I will add cinderblocks under the pallets and out of sight from SWMBO :eek:. Jay :rolleyes:
/ How do you store your attachments #19
Outside. In the dirt. Been that way for three years. Everything, including the tractor still look fine. (You ever seen tractors or implements at a dealership stored indoors?)
Having said that, as soon as I can scrape up $2k I'm going to build a 3 bay 30'x20' dirt floored shed. Hope to start in May......but I've been hoping to start for about a year now.
/ How do you store your attachments #20
N80:
My 3 bay has been on my list for years now :rolleyes:. Jay :)
2008 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2008 MACK CHU613...
Sundowner Rancher Express 20FT Livestock Trailer (A63118)
Sundowner Rancher...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 389...
2009 STERLING LT9500 (INOPERABLE) (A63569)
2009 STERLING...
2025 HD Trailer Solutions EQ15 T/A Equipment Trailer (A59230)
2025 HD Trailer...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
