dstig1
Super Member
- Joined
- Apr 7, 2010
- Messages
- 5,547
- Location
- W Wisc
- Tractor
- Kubota L5240 HSTC, JD X738 Mower, (Kubota L3130 HST - sold)
Overthinking it.
As long as the compressor is happy with the power suppy, you should be fine. Start it up once on that extension cord and see what you hear. Does it start like normal, or bog down a lot until it gets going? If it bogs, then you need to upgrade the extension cord. 3/8" can go a long way. A lot of flexible hose is 1/4" which restrict flow more. If you can run 3/8" most of the way and the 1/4" for the last 50' then you have the best of both worlds - good supply and flex for maneuverability. So if you have issues with bogging, move the compressor closer to and actual outlet (or directly plug it in) and run more 3/8"
