How far out can I extend a structure supported on one end?
   / How far out can I extend a structure supported on one end? #51
If you encase the ends of the beams in the end foundation, you will have integral foundation and just need rebar.
The integral foundation can have soil placed against it for smooth transition from ground to dock
Is that an approved often used type of application? You realise the beam end that is encased in concrete will be in tension?
   / How far out can I extend a structure supported on one end? #52
Integral abutments are used in Ohio, very common in Tennessee
   / How far out can I extend a structure supported on one end? #54
Integral abutments are common with multiple spans. Similar forces in abutment with cantilever or multiple spans. Highest tensile forces will be at support closest to water
   / How far out can I extend a structure supported on one end? #55
Those should be in compression.
   / How far out can I extend a structure supported on one end? #56
The beam would fail at the support closest to the water before it would fail at the end support from tensile forces
   / How far out can I extend a structure supported on one end? #57
Bottom flange, at waters edge of concrete = compression
Top flange, at waters edge of concrete= tension.
Edge of concrete at waters edge is the highest force for both
   / How far out can I extend a structure supported on one end? #58
Good program for beam analysis:
http://yakpol.net/gobeam.html
I think it's $35 to download the "non-professional" version.
I used it for a 25' and a 50' bridge using doug fir utility poles for beams.
   / How far out can I extend a structure supported on one end? #59
The water edge support is in compression. The land side support is in tension. The beam and the supports are different entities as are the connections between the beam and support. Lots of different ways for the connections.
A beam usually fails where sheer or moment values are highest.
[video]https://www.quora.com/What-are-the-types-of-beams[/video]
   / How far out can I extend a structure supported on one end? #60
Ld1
thanks for the helpful explanation
Egon
Supports can fail in the technical sense in that they allow excessive movement, but they rarely completely fail.
Most rolled beams will fail in compression of the flange in the area of highest moment if loaded as a cantilever. The highest moment would be at the support closest to the water
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
Stainless Steel 1" Spool (A52377)
Stainless Steel 1"...
2014 Morbark M12R Towable Brush Chipper (A52377)
2014 Morbark M12R...
2010 International Prostar (A47477)
2010 International...
2020 Kinze 3505 High Speed 6/11 Planter (A55302)
2020 Kinze 3505...
UNUSED HURRICANE STAND ON SKID STEER (A52706)
UNUSED HURRICANE...
