How important are tire chains on a 4WD for snowblowing?
   / How important are tire chains on a 4WD for snowblowing? #21
I agree with others. If you have a lot of ice or hard packed snow or have a driveway on a hill you will probably need chains.
   / How important are tire chains on a 4WD for snowblowing? #22
I have never used chains on my tractor and when relatively careful don't slip around too much. I have used a back blade, box blade, and FEL for snow removal (not a lot of snow in last 5 years.) - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - The back blade worked nicer when I turned it around and backed the tractor. This way I shove the snow beffore driving on it and packing it into ice. The box blade is a very HD unit and the extra weight gives me better traction. It has cutting blades faced both directions so I can use it like a grader blade when backing up. - - - - - - - - - - - - - - - - - - - - - - - - - - I have the maximum wheel weights (cast iron) that Kubota allows but the tires are not filled. The tires are industrials not Ag. - - - - - - - - - - - We average a lot less snow than do many areas, say North Dakota, Minnesota, and the other semi-arctic states. Oklahoma weather, snowfall included, is quite variable and varies from extreme to non existant in any given year. - - - - - - - - Pat
2008 TEXAS BRAGG 20 UTILITY TRAILER (A58214)
2008 TEXAS BRAGG...
Land Pride FDR1660 (A53317)
Land Pride FDR1660...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2015 Toro Sand Pro 5040 Bunker Rake (A59228)
2015 Toro Sand Pro...
2011 Toro Workman HD Utility Cart (A59228)
2011 Toro Workman...
2016 DRAGON SAND CONVEYOR (A58216)
2016 DRAGON SAND...
