How long for rafter boards?
   / How long for rafter boards?
That's a good idea.
After all that, the finance committee decided she didn't want to spend that much, so it's back to a flat roof design. Ahhh, I'm just along for the ride!
   / How long for rafter boards? #13
A squared + B squared = C squared
   / How long for rafter boards? #14
all one has to do is look at the rafter square, look at the rise, see what the number is, and multiply it by feet of run, and add the tail on to the number,
if you can do that take a chalk line snap out the distance of the building, and where the peak is, snap a line at 90 degrees (square) where the peak is and use the chalk line to snap out a rafter, on the lay out and take a tape measure and measure it out from the full scale template you layed out,
one can lay it out to scale 1 inch to the foot s well if you do not have a lot of room,
a common rafter is not that hard and you do not really need math to do it, if you have a framing square,
even the speed squared I think have some of the basic info on them,
I like the little Stanley book
http://www.tooltrip.com/tooltrip9/stanley/stanmisc/square.pdf
empire,
http://www.empirelevel.com/images/products/squares/17453.pdf
Irwin
http://www.irwin.com/uploads/documents/97_rafterinstructionmanual.pdf
1903 book if you really want to know how to use the steel square,
http://www.evenfallstudios.com/woodworks_library/the_steel_square_1.pdf
another Stanley for the quick square or pocket square
http://www.stanleytools.com/xhtml/literature/Stanley_QuickSquare.pdf
2018 Toro Groundsmaster 4000D Batwing Commercial Rotary Mower (A59228)
2018 Toro...
2015 Bobcat S650 Skidsteer - Enclosed Cab - 5462 Hours (A56438)
2015 Bobcat S650...
Bobcat mid mount mower M60-5 60" CT2025
Bobcat mid mount...
2007 MACK CV713 ELITE DUMP TRUCK (A60430)
2007 MACK CV713...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
2016 JOHN DEERE 135G (A58214)
2016 JOHN DEERE...
