How Many Hours on Your BX?
   / How Many Hours on Your BX? #1
Tractor Seabee
Elite Member
Port Orchard WA Kitsap Peninsula, West of Seattle
Kubota BX25
Just wondering about some of the posts on BX maintenance and the bragging about not having any issues. It seems the average user of compact tractor only put a max of 50 Hrs/year. My BX 25 is a 2011 year and I now have 1500 hours on it. I just lost 3 months of seat time due to my Gall Bladder emergency and surgery or it would be a lot more. Little things are starting to break now. If I had to take it to the dealer shop for every little thing I would never have it to produce work. The WSM has saved me a bundle of labor costs ($125/hr here).
So lets start a little poll on life cycle of BXs. Mine: 5 years at 1500 hrs. still only minor problems.
Ron
   / How Many Hours on Your BX? #2
Mine is 8 months old with 75 hours on it. Only thing that broke on it was a backhoe control lever. The part was replaced under warranty and I did the work.
   / How Many Hours on Your BX? #3
2009 BX25, about 700 hrs. No problems with the tractor, but the front tires leaked, so I got new ones and filled them. The seat is getting a bit worn, and the fuse went on the 12-volt outlet. All in all, a very reliable tractor. Money well spent!
   / How Many Hours on Your BX? #5
just short of 5 yrs. @ 370 hrs. BX25. primarily used for mowing.
  • front tie rod boots failed (cracked)
  • main driveshaft boots failed (cracked)
  • front tires lose air occasionally
  • top radiator hose started leaking recently. replaced it
the boot rubber is definitely a materials defect on kubota/supplier side. all failed within 20 months and have failed again since. wrote to kubota - no reply.
other than these, no issues.
   / How Many Hours on Your BX? #6
2002 BX22 with 1275 hours digging, tilling and general work with bucket and forks.
1998 B7300 with 2255 hours mowing.
Both still going strong.
   / How Many Hours on Your BX? #8
2011 BX2660, 500 hours, steering system hydraulic lines wore through against frame rail, I replaced them.
   / How Many Hours on Your BX? #9
2010 BX1860, 470 hours, used 4 seasons out of the year for all sorts of activities including mowing, tree pulling, aerating, PTO generating, snow moving, FEL'ing, and so on. No inherent product quality issues to date. I self-inflicted a few problems, for example just about tearing off the left side ROPS-mounted blinker/indicator light assembly and breaking one of the lenses in the process. This was due to a tree and associated branch that came at me out of nowhere.
ps
I would be interested to know whether folks having issues with rubber boots (etc) store their tractor indoors or outdoors. Mine is stored indoors (in a non-climate controlled environment, but out of the sunlight).
   / How Many Hours on Your BX? #10
I'm not sure of how old, probably about 8 years old, has 600 hours on it. All my problems I would consider minor. My current problem is a problem with the steering, its my understanding some O rings need replaced, but the problem comes and goes.
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2016 Ford F-150...
2013 Freightliner M2 Box Truck (A59814)
2013 Freightliner...
24017 (A56859)
24017 (A56859)
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2003 INTERNATIONAL 9900I (INOPERABLE) (A58214)
2003 INTERNATIONAL...
Lufkin CM-320D-305-100 T/A Oil Field Pumpjack (A60460)
Lufkin...
