How many mechanicts to change a tire?
   / How many mechanicts to change a tire? #41
Wonder who disabled the clutch interlock?
Jim
No need to wonder, the owner put an aftermarket clutch in it and said it then became irregular working sometimes and not others.
   / How many mechanicts to change a tire? #42
I used to manage a service center. If we damaged something, we fixed it. If we disabled your vehicle, we provided a rental. If the repair we outside of our skills, we paid someone else. If it was a POS, we negotiated a settlement. No argument. Yes, sometimes it hurt.
   / How many mechanicts to change a tire? #43
I guess I'm not the only person that thinks a reasonable repair / settlement is in order. just a good way to do business.
I remember one lab I worked at. if we borrowed a piece of equipment from another department.. we sent it back in better condition if possible, than we borrowed it. IE.. cleaned, serviced, repaired.. etc.
I try to do that nowadays if I ever borrow something..e tc ( which i usually try to avoid anyway.. :) .. as if it's worth needing.. it's worth owning.. )
soundguy
   / How many mechanicts to change a tire? #44
They don't have to lift a car as high as the mechanic just to change a tire. Gosh, wonder what would they to fix its radiator, turn it upside down???
   / How many mechanicts to change a tire? #45
Seems to me the owner of the truck will likely share some responsibility.
   / How many mechanicts to change a tire? #46
If you think starting a vehicle by reaching through the window is good practice as a business then go for it. Lube place picked up the whole bill including a commercial rental for the duration.
   / How many mechanicts to change a tire? #47
There is always the possibility that a vehicle with a manual transmission will come in for service that has a defective clutch safety switch or even never had one. I've heard that clutch safety switches were first introduced in North America about 1970 so if you had an older vehicle, there is no doubt in my mind that 99.99% or more of the workers nowadays would not realize that it has no clutch safety switch. Leaning in through the window to start an unknown vehicle and expecting it to not drive away is an act of faith, not due diligence.
   / How many mechanicts to change a tire? #48
Great!!!
   / How many mechanicts to change a tire? #49
Yeoow, what a mess, did it cost the mech.his job? Sometimes it might?
New/Unused AGT Air Compressor (A57454)
New/Unused AGT Air...
2016 FORD F-550 UTILITY / MECHANICS TRUCK (A59575)
2016 FORD F-550...
Kubota B2601 Utility Tractor (A57453)
Kubota B2601...
New/Unused Quick Attach Auger with Three Bits (A57453)
New/Unused Quick...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
2023 CAN-AM DEFENDER RTV (A59823)
2023 CAN-AM...
