how many units of diesel/hour for CUT's
   / how many units of diesel/hour for CUT's #21
I asked my son how much fuel he was using in the 755 (20 hp) doing different jobs last spring and summer. Pulling a planter about .5 gallons per hour. Bush hogging about .75 gallons an hour and pulling a 6 ft. disk about a gallon an hour. In a hundred engine hours last year the 755 burned about 83 gallon of fuel.
   / how many units of diesel/hour for CUT's #22
On my L3400-- I would say between .5 to 1 gallon per hour..
scraping, box blading .5 to.75 (I have some big hills that really burns the fuel when I drag a full box up them!)
Loader work-- Heavy work is a full gallon per hour..
light stuff- .75..
On some of my 10 hour days on the weekend I have gone thru a full tank and then a little bit more!
Later,
J
   / how many units of diesel/hour for CUT's #23
Aviation tought us that a rough guide when detailed specs were not available was 5 US gals per hr per 100 hp. using avgas.
   / how many units of diesel/hour for CUT's #24
Best I can tell my JD4700, 48 engine HP, gets uses about 1/2 gallon per hour doing FEL work, splitting wood, box blading. Hook up the mower and run at PTO speed its about 1 gallon an hour.
Even when the price of fuel was getting close to $5 a gallon when you looked at the work done per hour it was a deal. :D
Later,
Dan
   / how many units of diesel/hour for CUT's #26
I have a 28HP Jinma 3 Cylinder Diesel 4x4 Tractor and its mainly used for Logging (30 hrs per year), mowing pastures (60 hrs per year), and other chores with the PHD Grader Blade and Box Blade (30 hrs per year), and it has averaged .75 gallons per hour. My tractor has 575 hours since 2004 and I know the 150 gallons the Co-Op delivers last a good 1.5 years.
Seems like all the 25-30 HP tractors do about the same.
Chris
   / how many units of diesel/hour for CUT's #27
Chris,
I've noticed that Loretta's 28hp 284 Jinma (new 2008 with 150 hours on it) uses just as you said ... about 3/4 gallon per hour.
What's even more amazing to me is that my 2005 Kama 554 (55hp with 650 hrs on it) uses about the same ... 3/4 gal/hour. For as much power as it has and as much as the 4x4 unit weighs, it is very frugal in the fuel department.
Rob-
   / how many units of diesel/hour for CUT's #28
Chris,
Rob-
I would wonder why the Kama is so gentle on the fuel for sure..
Of course there is always maybe the Jinma is just being a guzzler-- But I know better than say that about Loretta's pride...
Later,
J
   / how many units of diesel/hour for CUT's #29
My JD4700 48 HP 40.5 PTO HP gets about .5-.75 GPH running non PTO speeds doing wood splitting, FEL work and box blading. Put on the mower and got to PTO speed its around 1 GPH best I can tell.
Later,
Dan
   / how many units of diesel/hour for CUT's #30
My 4200 (26hp) is getting around .25 gal/hr. Not doing any pto work just loader work.
M.D.
2020  FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2020 FREIGHTLINER...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2021 MDB TF150R 84" HYD MULCHING HEAD (A51406)
2021 MDB TF150R...
2020 CHEVROLET SILVERADO 3500 HD FLATBED TRUCK (A57192)
2020 CHEVROLET...
20-Ton Hydraulic Bottle Jack (A55852)
20-Ton Hydraulic...
