How much can a 40hp tractor tow??
   / How much can a 40hp tractor tow?? #1
IslandTractor
Super Star Member
Prudence Island, RI
2007 Kioti DK40se HST, Woods BH
Can a 40hp tractor tow a 9000-10000lb boat/trailer up (and down) a 5-7% grade? Speed not an issue. Just moving a boat trailer to and from a boat ramp on rural dirt road. Mostly flat except for one hill.
   / How much can a 40hp tractor tow?? #2
I'd be real careful going down and I wouldn't do it unless the trailer has brakes.
   / How much can a 40hp tractor tow?? #3
Halfway down the hill your knee bumps the tractor into neutral when you look back. Can the tractor stop the trailer when going downhill? How about a trailer brake controller on the tractor?
Bruce
   / How much can a 40hp tractor tow?? #4
Does the trailer have hydraulic surge brakes or electric brakes?
   / How much can a 40hp tractor tow?? #5
That seems well within range to me. Even my wimpy Mule 600 is rated to tow that much.
Your Mule can tow 10,000 lbs on a 5-7% grade?
I need to see this.
   / How much can a 40hp tractor tow?? #6
I'm not worried about stopping that small of a trailer. You wouldn't hesitate to go down that hill with a bucket full of gravel which weighs more than that.
Did you see all the zeros?
Bruce
   / How much can a 40hp tractor tow?? #7
Did we have some post editing? I could have sworn it said 900-1000 pounds. I'd be way more concerned about 9000-10,000 pounds.
27ft boat displacement dry 6000lbs. Figure 1000lbs fuel, water, supplies and 2000lb tandem bunk trailer so 9000lbs or so.
Tractor has HST and would use low range up and down the 5-7% grade hill. Trailer has hydraulic surge brakes.
Doable???
No editing but it is late!
   / How much can a 40hp tractor tow?? #10
If you decided to do it use 4WD otherwise you don't have front brakes.
2011 Ford F-250 Crew Cab 4X4 Pickup Truck (A55788)
2011 Ford F-250...
2018 Nissan Titan 4x4 Crew Cab Pickup Truck (A53422)
2018 Nissan Titan...
2018 FORD F-150 XL CREW CAB TRUCK (A51406)
2018 FORD F-150 XL...
40' CONTAINER (A54757)
2016 Club Car Precedent Electric Golf Cart (A53424)
2016 Club Car...
2017 Ford Transit 350 Handicapped Van (A55788)
2017 Ford Transit...
