How much does that dirt weigh? or, Overloading 101
   / How much does that dirt weigh? or, Overloading 101
If you put in too much, you press the button and nothing happens (it doesn't go up), then you are really in trouble.
DAMHIK :eek:
It had no trouble lifting this load.
I'd like to load it and see how much it will lift.
Trouble is, if it won't lift it, then I have to shovel it out by hand.
I'm not sure I remember how to use a shovel. ;)
   / How much does that dirt weigh? or, Overloading 101 #12
DAMHIK :eek:
Nahhh, just lifting the front, or shoveling the back. :D
At least that is what I heard :eek:
   / How much does that dirt weigh? or, Overloading 101 #13
DAMHIK :eek:
Yeah, that's a problem! You have to drop the tailgate then back up real fast and slam on the brakes until you can shift the load and dump it.:D Or use a shovel:eek::eek::eek::eek:
   / How much does that dirt weigh? or, Overloading 101 #14
If you got the bigger trailer to haul your tractor too, just drop the gate and drive in with the loader to remove the dirt - No shovel necessary!
:D
:D
:eek: never thought of that
   / How much does that dirt weigh? or, Overloading 101 #17
The best way to find the weight of any dirt, sand, or gravel is to pick up a shovel full of it, over and over. Hands down, the heaviest muck out there is wet clay. Not only is it harder to pick up, it's harder to put down.
1998 REINKE TRAILER HEAVY HAUL TRAILER (A58214)
1998 REINKE...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A56438)
2012 MACK Tender...
Ford 8510 (A53317)
Ford 8510 (A53317)
John Deere 690B Excavator with Auxiliary Hydraulics (A57024)
John Deere 690B...
2026 tilt trailer (A56859)
2026 tilt trailer...
24in pin on excavator tooth bucket (A56436)
24in pin on...
