HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20
   / HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #61
I finally got around to doing this. Outstanding instructions by the OP! Thank you again!
   / HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #62
I had to adjust my GC 1710 it was a little low. Now it is back good again.
Thanks for posting this.
   / HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #63
Doing this adjustment increases the backhoe pressure also correct?
   / HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #66
FWIW the hoses have a 3000psi working pressure rating. Burst pressure is much higher.
   / HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #67
That said don't crank the system to 3000psi. Going over spec is NOT recommended. Things like front axle aren't built to handle the corresponding strength gain that would result from over tuning the prv
   / HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #68
The pump wouldn't stand the 3000 Psi if the specs call for 2000.
   / HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #69
For the record I am not recommend raising the pressure that high. More just pointing out the difference between working and burst pressure on hydraulics.
I think the tires would be maxed out before the axle. Which is just as dangerous if you don't know what your doing.
I wouldn't be surprised if the pump could. My understanding of the exact workings of the system isn't strong yet, but I'm assuming the transmission must run at higher pressure than the implements to be able to bog the engine down. Could just be the flow that loads the engine. Does it use a separate pump?
That being said, I don't think there would be any usable gains on the FEL at that pressure over 2200 maybe 2500. The rest of the tractor just doesn't seem to be designed for it. As mentioned above, the axles and tires alone. Then you have the pivot points that may not hold up, the increase wear on the pump, heat generated, valves, ECT. Doesn't seem to be worth it to go that crazy.
It would be interesting to do some testing to see what actual results are and understanding the limits.
   / HOW TO: Adjust the Pressure Relief Valve (PRV) on the MF GC 1705/10/15/20 #70
After buying the tool from Bolt on Hooks and finding out they do not sell the correct fitting for a GC1720 I ended up just having a hydraulic shop make a pressure gauge tool. Cheaper and better in my opinion. I could hardly believe that the fitting from Bolt On (for a GC 1705 from the chart, my mistake even though I did specify for a GC1720 on the order) was literally fused to the threads and was not removable. The response from Kenny was 擢irst time I致e heard of that problem which seemed to make it not a problem in his view. So, I知 the price of his pressure gauge tool and he痴 out a customer. Not the best trade but that seems to be the way it is.
Honda Pioneer SXS700 4X4 Utility Cart (A55787)
Honda Pioneer...
2015 UTILITY VS2RA 53FT REEFER TRAILER (A57880)
2015 UTILITY VS2RA...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
ACS 104" HYD PIN ON PIPE GRAPPLE (A52707)
ACS 104" HYD PIN...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2015 Peterbilt 320 Trash Truck (A55973)
2015 Peterbilt 320...
