How to buy a TIG?
   / How to buy a TIG? #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
So just asking the group as it seems Tig Month for questions... Looking at an Everlast 200DV (its my price point and I have had good luck with my other Everlast products). I could go up a bit in my purchase price and am considering the 250.
I guess my question is given the fact I couldn't make a good looking weld if I tried and I struggle to figure out the difference between aluminum and steel, but I thoroughly enjoy welding and have made many cool things and most of them have held together... what TIG should I get. I have never been 100% happy with my Lincoln 180C. Always felt it was a bit underpowered for my use on the farm (I do have a stick and it does all my heavy lifting so I am not completely SOL). I don't want to buy underpower on a tig (1/4" aluminum and 1/8 copper seems to be on my radar). I also don't want to overby on technolgy. I look at all those settings on the 250 and I say I am never going to build a nuclear reactor.
Guidance?
   / How to buy a TIG? #2
The way I see it the decision is relatively easy for you.
You're already familiar/ happy dealing with Mark and his products. It's just a matter if you want to invest the extra couple of dollars for the 250 amp machine (or not).
You've already indicated that you "could go up a bit in your purchase price" so do it!
*I guess it's true. It really IS easy to spend other people's money.
Terry
   / How to buy a TIG? #3
Take a look at the 210 EXT. I think that will give you the best of both worlds, with just enough extra power to handle everything you'd likely encounter.
   / How to buy a TIG? #4
I have a DC TIG, but now I want AC to weld Aluminum. Seems like I need enough power to weld 1/4" Aluminum, so what's it take to weld 3/8? I have 240v 30A.
   / How to buy a TIG? #5
3/8 will require 300 amps to get it right unless you don't mind bevel with multi pass. It's just difficult to keep a good puddle on the thicker stuff with less. Unless you run 100% Helium. 300 amps may kick that 30 amp breaker. Check input amps on the machine. On 1/4" and thicker I prefer twin pulse mig with push pull.. Tig looking welds, with mig speeds. Actually it's my go to process because I can do 1/16-5/8+ with 3/64 wire. Because of this, My ac/dc 200 amp just sits on the cart. Guess I'll sell it.
   / How to buy a TIG? #6
I haven't used my spool gun in quite some time.
First two pictures are on 1/16-inch thick aluminum. With .030 wire.
Third picture looks like maybe 1/4-inch thick aluminum. With 3/64 wire.
2019 GALYEAN 150BBL STEEL (A58214)
2019 GALYEAN...
2012 BIG TEX PIPE TRAILER (A58214)
2012 BIG TEX PIPE...
2013 Freightliner Bucket Truck (A55973)
2013 Freightliner...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- DEMO UNIT (A61306)
Greenworks...
(INOP) VOLVO A30D OFFROAD DUMP TRUCK (A60429)
(INOP) VOLVO A30D...
