How to Join 6" PVC to 6" HDPE drain pipe
   / How to Join 6" PVC to 6" HDPE drain pipe
Hi Dave,
That's a good point, and I will be more careful about "deals" in the future.
We have grading/drainage plans, and we have a contractor who said we could use this stuff. He just said it might be a higher grade HDPE than we needed on the buried line, and that it would a . He did the math expecting the PVC fittings to be expensive, but it turned out the PVC pipe is bell ended.
Worst case scenario is I spent an extra $100 to upgrade 200 feet of the foundation's buried drain pipe from single wall corrugated coil to double wall smooth inside HDPE. The 6" PVC pipe cost less than parallel 4" PVC pipes it would likely replace, so I don't think it will be a loss money wise, but it is a bear to move.
Todd
   / How to Join 6" PVC to 6" HDPE drain pipe #12
Fernco makes a "strong back" fitting that is extra thick and has a stainless steel band around the outside of the rubber.
2020 Ford F-250 4x4 Crew Cab Pickup Truck (A60460)
2020 Ford F-250...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
