How to paint a tractor...
   / How to paint a tractor... #21
Spiveyman said:
Good point on the Darwin awards, I'll be watching the local paper and let you know when he nominates himself. Actually, the guy said he used to paint tractors, but his insurance company shut him down. What's that old line about God watching over fools and little children? Looks like his insurance company probably saved his life.
The tractor is in decent shape, there's a place where the fiberglass front hood is busted, and a crease in the top cover over the engine, and normal wear spots in the tractor like where you put your hand behind the gas cap to get off the tractor. I just like to take care of my stuff, I certainly worked hard enough to be able to afford it, so I want it to reflect my "work ethic" and taking care of my stuff. Thanks!
Those small parts.. if they bother you, can be addressed seperately of the entire unit.
For someone learning painting. have 3 pieces of sheetmetal hanging on a line is a whole lot easier than prepping an entire tractor for painting.
1, that fiberglass nose can be removed and repaired.. or replaced... Fiberglass is EZ to fix... even if it needs a wire frame inside to prop the resin cloth on till it cures.. then sand smooth and contour the fb.. use glaze putty or other filler to get minor surface imperfections. then sand entire nose piece to uniformity... Prime it.. follow directions on whatever paint you use... some require wetsanding.. or scuffing afterwards.. or some have windoes of recoat time.
Then paint it.
same with that dash .. it is seperate of the 2 hood front sections.. though much more labor intensive to remove.. however.. with a roll of tape and a few big sheets of mask paper.. you CAN pain it in place if you take your time.. just prep, prime, paint.
Either of the hood sections are EZ to remove...
If the crease is repairable do so.. IE.. lay the crease down on a wood plant and work it with a dent hammer fromthe other side and a rubbing block if needed... Use a glaze or filler putty if needed to finish off imperfections.. sand, prime, paint..
Douing small tasks like a hood panel or a front nose won't be nearly as bad as the entire job.
Might be a fun learning experience.. and at worst.. you have 3 parts that have marginal paint... which.. sounds like they are no worse off than before... etc.
Even if ya don't paint he hood and dash... do go ahead and fix the nose.. that will be the easiest part.. Even if yuo rattle can prime and paint it afterwards.. it will dress up the entire machine by not having a crushed piece on it.
Still.. as the others have said... she looks like a worker not a parade queen. My worker 7610 has a few warts that i havn't addressed... Like a crumpled left fender courtesy of the previous owner. I just added paint to prevent rust. On a later date.. when the rest of the tractor is ready for paint.. I'll fix the fender.. sheet metal is even easier to repair than fiberglass..
Soundguy
   / How to paint a tractor... #22
While not 'rare'.. the Allis model 'G' are not super common either.
They are a good cultivating tractor with a 62 ci engine.. similar in hp range as a cub.. or massey harris pony.
I see about 3 for sale per year.
There was a guy that lived north of me that restored them and repowered them with isuzu diesel engines for years.. but he got out of the business. Had I had more $$.. I could have picked up quite a few of his unrestored carcasses when he started to sell out.
It's a neat little tractor.. still 6v.. etc. Starts easy.. sips fuel. I use mine solely for parade / show work. She stay washed and waxed and garaged. I drive her about 1x per month down around our neighborhood to keep her limbered up and to get her up to temperature for a while to prevent moisture from settling in the oil sumps.. etc..
schmism said:
were do i get one of these?!?!
   / How to paint a tractor... #23
Soundguy said:
Be fair now...You are taking this statement somewhat out of context. I did not state that only those 'alergic' to it would / could be affected. If you are especially sensitive to the ISO compounds .. you will have a much more sever reaction.
And yes.. go to the ytsite.. this exact same info is discussed over there.
Also... according to the info from some of the hardners.. fresh air painting is acceptable under certain conditions.. It's in black and white.. you can hit valspar's MSDS to verify this..
Also.. As i indicated in my 1st post, I too believe his OEM paint is still sufficient and should not be re-coated yet.
Soundguy
Fresh air painting is "acceptable" to some, but there's little control over environment, so conditions aren't consistant throughout the process. Even the slightest amount of wind drift would carry dangerous iso's to where ever the wind wants to take it. Not the safest way to paint. Sorta like rolling dice IMHO. Are those MSDS from Valspar CURRENT? I've seen older MSDS sheets and/or paint cans with that sort of info, but I do believe that fact has changed in the past few years. Here's the latest MSDS info I have in hand for Valspar hardener;
"Caution- Contains alphatic polysocyanate isophorone diisocyanate, naptha, and n-butyl acetate. Individuals with lung or breathing problems or prior reaction to isocyanates must not be exposed to any vapor or mist. All others, do not breath vapor or spray mist. Wear an appropriate, properly fitted respirator (NOISH approved) during application. Use a positive pressure airline resperator. (NIOSH approved) and follow respirator manufacturers recommendations for respirator use. Do not get in eyes, on skin or clothing. Wash thoroughly after handling. Keep away from heat, sparks or flame. Vapor may cause flash fire. Notice; Test reports have linked use and exposure of isocyanates to permenant lung damage. Reports have associated repeated and prolonged occupational exposure of solvents to permenant brain and nervous system damage. Misuse by deliberate concentration or inhaling the contents may be fatal. For industrial use only, use under compliance with EPA and OSHA."
This MSDS sheet is dated Jan 1, 2006.
Same info on latest can of hardener I have. Less restrictive warning on older cans I still have on the shelf.
Google "Isocyanate exposure" for a less "sugar coated" version.
Those more susceptable to ico's are in more danger, but NO ONE is immune to their effects. Any exposure will have effects, however slight they MIGHT be. Sometimes they won't be immediately noticable or even detectable at all, but they are DANGEROUS. Effects don't always show up right away. It was 2 years after exposure, and during a bout with the flu where my first symptoms occured. Even a less severe reaction is still not something anyone would want. Exposure is avoidable. Not taking all the precautions available is like Russian Roulette. Why take the chance? Since effects aren't reversable, there's no good reason to wait until after a person detects symptoms to take neccisary precautions.
Yep, There's no way even the very best painter can replicate conditions of an original pant job. That would require complete disassembly, stripping to bare metal, removing ANY rust, completely cleaning everything, and painting in almost sterile conditions. That said, why anyone would repaint a tractor in that good of condition is beyond me.
Soundguy said:
That 2nd coat of paint you put on will help delay the rust of those 2 implements.
The finish didn't turn out perfect due to the metal surface and old paint imperfections. Same would be true on the tractor.. Like I said.. most of the 'finish' look comes not fromt he paint.. but from the labor involved during surface prep.
As i said at the bottom of my 1st post.. your 6610II work clothes are fine.. My 7610s has very similar ( oem ) paint..
Soundguy
I think I pretty much proved your point about the most important thing being the prep work. I just painted a boom pole and put much more time in up front scraping the crap off, sanding, and even priming this time. That made a really big difference, and I'm using a brush. I can only imaginge how much better it would look with a spray gun.
Thanks for the compliments on my tractor's current state. I'll have to say I really like your 7610 as well. Your's seems to be in better shape, but I'm not dogging on mine. I know I'm crazy to want it to look new, and I take to heart all the comments about the OEM paint. I think I'll take your advice in your next post and try to fix the body damage. Then perhaps I'll take some smaller pieces that are in worse shape and try to touch them up as stated. I'll take full caution with the breathing thing just in case.
I don't have a dent hammer, and don't even know what a rubbing block is, but I can probably figure it out. Like you said, it will be fun. Which by the way is half the point for those who still question my sanity. :D I get as much enjoyment from taking care of my stuff as I do from using it. I know what you mean about her not being a parade queen, but she's mine and I want her to look as good as I can get her to look.
I was going to work on it a bit tonight, but someone broke into our house this afternoon, ransacked the place, stole stuff and did lots of damage. I had to replace the back doors and frame. Had to use some of my tractor project money on the repairs and we haven't even figured everything that's missing. Once things settle back down I'll post some b/a pics of anything on the tractor I can manage to fix.
Funny thing is this whole evening I kept thinking about the coyote thread in the Country Living forum and wanting to use some of those ideas on these burglars. :mad:
   / How to paint a tractor... #25
I'll have to find my MSDS.. i think i got it saved at home PC. Don't recall date off hand. but very well could be older than yours. I havn't done any painting in 07 at all..
I agree on the environmental conditions... no real control.. IE.. you wouldn't want to try to make a show paint ob outside.. A spec of dust is all it takes.. or your neighbor putting some silicone tire spray liberally on his tires upwind from you.
I'm no show painter.. i paint my machines solely for preservation.. the fact that a few of them came out real nice had some luck involved.
I will say that I did take lotsa time with my best job.. the Allis G Complete disassembly is easy on a small machine.. though i did have to buff out and re shoot the rear hood cowling due to an imperfection.. Might not have done so .. except the rest of the tractor had turned out so good.. i couldn't leave that 'wart' on there.
That's the main reason i havn't repainte dmy 7610s. OEM paint is still holding.. and even the few areas it is worn a bit.. it's still intact and primer is good.... No use in recoating good paint on a worker that see's brush and shrubs al the time.. at least not while there's still intact paint on her anyway.
Soundguy
   / How to paint a tractor... #26
Spiveyman said:
I think I pretty much proved your point about the most important thing being the prep work. I just painted a boom pole and put much more time in up front scraping the crap off, sanding, and even priming this time. That made a really big difference, and I'm using a brush. I can only imaginge how much better it would look with a spray gun. :
Yep.. no pain.. no gain... You are getting the feel for it now.
Spiveyman said:
Thanks for the compliments on my tractor's current state. I'll have to say I really like your 7610 as well. Your's seems to be in better shape, but I'm not dogging on mine. I know I'm crazy to want it to look new, and I take to heart all the comments about the OEM paint. I think I'll take your advice in your next post and try to fix the body damage. Then perhaps I'll take some smaller pieces that are in worse shape and try to touch them up as stated. I'll take full caution with the breathing thing just in case. :
I'd bet our 2 tractors are are in closer condition than is apaprrent. My chassie paint may be a tad better.. but your tires are much better than mine. I've got a dented left fender that is probably as attractive as your cracked fiberglas nose piece.. etc.
That series of tractor.. the 5xxx, 66xx and 7xxx were some of the best ones ford/NH/CNH ever turned out in my opinion.
Doint it in small pieces gives you a feel for it.. and worst case is yuo can't really 'ruin' anything past what you can sand off in a few hours and repaint.. etc..
Spiveyman said:
I don't have a dent hammer, and don't even know what a rubbing block is, but I can probably figure it out. Like you said, it will be fun. Which by the way is half the point for those who still question my sanity. :D I get as much enjoyment from taking care of my stuff as I do from using it. I know what you mean about her not being a parade queen, but she's mine and I want her to look as good as I can get her to look.:
Google body work.. and you can improvise tools.. everything from a simple as a hand sized piece of 2x4 and a small hammer with a large flattened head can do some pretty superior body work with patience. Just don't overwork the metal.. you can actually stretch it.. though tractor tin is a wee bit thicker than car body panels.. so you have more 'meat' to work with.
When yuo re-glass the nose.. don't be afraid to use a stiffener made from hardware cloth or tin flashing on the underside as a form for the cloth/resin till it sets. I've used that 1/4 and 1/2" hardware cloth as a template or framework for many a filler/resin/cloth project.. it's a good crutch or cheat for those of us that lack the real skill of a seasoned body profesional..
Spiveyman said:
I was going to work on it a bit tonight, but someone broke into our house this afternoon, ransacked the place, stole stuff and did lots of damage. I had to replace the back doors and frame. Had to use some of my tractor project money on the repairs and we haven't even figured everything that's missing. Once things settle back down I'll post some b/a pics of anything on the tractor I can manage to fix. :
ARGH!.. I feel for you.. we have had breakins just down the street.. one woman was robbed while home with her kids... Luckilly they just wanted her stuff and left fast..
Good luck!! And i hope they find the people and nail their hide to the wall...
Soundguy
   / How to paint a tractor... #27
Soundguy
One of my oldest friends owns a classic car restoration business. Some of his work has ended up in a few of the most famous car collections out there. (Jay Leno, Reggie Jackson just to name a couple) He has one rule. "The job takes as much time as it needs to be PERFECT". I've seen cars spend an entire year in his shop just to get one small detail just right. While that may be extreme, especially in the case of a tractor, but that's the sort of attitude you have to have, to a greater or lesser degree, to get one perfect. On my MF150, I painted the hood, stripped it, repainted, stripped again, and repainted again. And guess what? It comes back off AGAIN this winter for one more try. All because of one minor flaw. And I'd bet that if I had 10 people lok for that flaw, 7 out of 10 couldn't find it. But I know it's there. A year and a half so far, probably 400 to 500 hours. A bit obsessive maybe, but everyone has that one project that HAS to be right. This was mine.
When I painted my 3000 Ford, the entire paint job, clean-up through decals took 3-1/2 days. The "rush" shows. I've painted a few to sell. They got about the same effort.
The 2440 was somewhere in between. It took about 3 or 4 months of spare time work.
I'm trying to convince myself that I don't need to be so obsessive when I start on dads old Ferguson F-40. I'll do it right. I'll do it carefully. But It's not a museum piece.
Long story short, ONE "Rembrandt" is enough for a lifetime. It's worthwhile for the education in painting, but I'll NEVER spend so much time again, ESPECIALLY on a tractor that'll be bush hogging, plowing, discing, baling hay, and just being a "tractor". Sure was proud of it when it rolled out of the shop though!
   / How to paint a tractor... #28
Funny thing happened. After i painted my 5000 ( really needed it.. ) My wife see's me out there hooking it up tot he mower one day and runs over and says.." You aren't going to use it now that it's all pretty are you".. and she said it with genuine angst in her voice.
I had to break it to her gently that I couldn't let a 7500$ /70 hp piece of iron set there while the grass gre just because it was shiny... It really took her some time to come to terms with that. i think she really thought i sunk that much cash into a hay ride puller...
Incedentally.. that paint job had a tragic point. I had just painted it and had rolle dit out from under the barn... went inside to get a soda.. walke dback out and it was full out raining.. Went from clear blue to thunderstorm in? 30 seconds..
After the nice 'texturized' paint cured.. i wetsanded it with 400 then 800 then 1000 and re-shot it. in the end it turne dout better as i had that additional coat of paint on top o fthe 2+primer it already had.. but still... My throat choke dup when i walked outside that day and say the dark sky and rain where there had been sun only seconds ago...!!
Soundguy
Yep, I love that series of Fords. They just don't make 'em like that any more.
I took a break from working on fixing the doors and ran out to take some better pictures of my tractor. Here's a couple shots showing the whole thing with the completed carry all on the back, and some shots of the areas that I'd really like to do something about, the FG dent, the creased hood, and the places that are rubbed through the paint, primer, and down to the bare metal. It seems that I should do something at least to those spots to keep it from rusting out. Although I do keep it in the barn now, so it's not in the elements all the time.
I can see my wife asking the same question about actually using this thing if I had it back in near perfect shape. For a working tractor there is something liberating about having some "character" because you don't freak everytime something happens to it. The other thing that just kind of dawned on me, I'm getting a FEL mounted next week. You won't hardly be able to see the tractor once that thing is on it! :rolleyes:
   / How to paint a tractor... #30
Mornin Tim,
If you could get that big Ford to fit inside a spray booth you wouldnt have to worry about any of those nasty fumes ! ;) :)
   / How to paint a tractor... #31
If you think the body work and pre-paint prep takes a strong stomach, try adding getting it apart and back toghether. It almost looks hopeless at a few points. Especially when you decide you need to rebuild things like the front end, transmission, engine, clutch, differential, etc.
I guess if it's worth it in the end...
   / How to paint a tractor... #32
Spiveyman said:
Not sure if this is the right place for this thread, but it's as close as I could find. I just bought my first tractor, Ford 6610. I bought it on the internet, so I don't really have any local contacts tractor-wise. It's generally in pretty good condition for a 1991 with 4,000 hrs, but there are some spots that I'd love to have touched up, or just have the whole thing painted. Problem is, NO ONE seems to paint tractors around here any more.
First: Aany locals (central KY) have a clue who might be willing to do this for me?
Second: If not, anyone have any advice if I decide to do it myself? I don't know much about painting, or have the equipment. I've heard one "tip" so far, cut the paint with gasoline when you spray because it will leave a really good shiny finish, but keep a flame burning on the ground and fan going to control and disipate fumes.
Or, should I just accept the tractor as is with some character because it's going to look like that again in a few years even if I do paint it. :)
Here's the photo's from the internet ad, I haven't taken any of it yet.
Last month I finished painting my 1964 MF-135 diesel. First tractor restoration project I've attempted.
To keep cost down I used a $40 HVLP spray gun from Harbor Freight and $35/gallon Valspar tractor paint from Tractor Supply. I thinned the paint with VM&P naptha per the instructions on the paint can. The engine, tranny and rear end are MF silver and the sheet metal is MF red. Three coats.
Of course, it's important to get the tractor really clean before spraying. Detailing that tractor probably took upwards of 100 hours since it was filthy. I power washed the entire tractor about 5 times (not including the radiator which was cleaned by hand). Then I detailed the tractor using Simple Green, Dawn dish washing liquid and mineral spirits. Lotsa nooks and crannies in the engine had to be cleaned (tediously) by hand.
To do the job right you should strip all the sheet metal off the tractor. In the case of the 135 the fuel tank had to be removed to clean the top of the engine. I also removed all the gauges, the steering wheel and the instrument panel that carries the gauges. I replaced all the gauges except the fuel gauge/sender unit and rewired the tractor. I set up a temporary spray hood on one of my workbenches for painting the parts that I had removed from the tractor.
When I get the tractor reassembled I'll post a few photos. In general I think the paint job turned out OK, considering my limited ability with a spray gun. You can spend a lot more than I did ($500 spray guns, $100/gal super paint), but I'm a novice at this so I started small and cheap.
   / How to paint a tractor... #33
Mornin John,
Yeah, now thats what I call rollin up your sleeves and gettin into the thick of it ! Id be comfortable in that shop ! ;)
Wow, JB, looking at those picture gives me heartburn! :eek: :D
Awesome job though. I'd love to have the confidence mechanically to rip one down that far AND be able to put it back together. I'll DEFINITELY start smaller, a panel here and there. Like I said, maybe hit the real trouble spots to hold them over until the whole thing really is ready for a make-over.
One question on the job above... did you have any parts left over after putting it back together? :) Or am I the only guy who's done that?
   / How to paint a tractor... #35
John Bud
I'm amazed how guys like you can strip a tractor down into hundreds of pieces and get it all back together, by the way it looks great.
Harvey
   / How to paint a tractor... #36
Heck.. sometimes we are too...
Soundguy
Harvey
   / How to paint a tractor... #37
LOL I always have an extra screw. :D The only reason i would repaint any thing would be to repair or rustproof it. Me car hood gets painted as soon as we get moved in. that paint proly wont look good or match the rest of the car but once i get that rust off it is goin to stay off! :mad:
   / How to paint a tractor... #38
Harvey7 said:
John Bud
Harvey
Well, there were a few points where my head kept on saying, "What the He#$ have you gotten into?" But, being more stupid and stubborn than realistic, I went ahead.
On old iron, 44 years old in that one's case, there have been many *ahem* shall we say, "customizatons". You look in the parts book for the break down, find that what you took off ain't what Ford put on. That's hard. What's worse is finding broken things that need fixing. I just picked a sub-assembly to do every week or two and pretty soon it was done.
As for extra parts. Well, there is a 5 gal bucket full of gears, shafts and countershafts from the transmission. I replaced the instrument cluster and back sheet metal so there are some left overs there. I had to design and bend up from scratch the PS hard lines and have soft lines made to fit. Many rev's of tube that got bent at the wrong angle. Had to figure out the boomarang shaped pivots for the hand throttle and foot throttle from pictures and then cut them out of sheet stock & grind to fit. So, there's some extras there too. Then there's the trans case that was too cracked to save - had to replace. Ditto for the differential housing. So, there are a few extras laying about.
It is weird, but I have a feel for bolts and can tell you pretty much what each one is for and where it goes. But, when you are holding a part that needs a half dozen bolts and you don't even remember taking it off ! That's why I bought over $300 in bolts and nuts (grade 5 and 8). Many of the take off bolts were a total mish-mash of what ever some clown had handy. Allen head's next to grade 8 next to who knows what. Age and rust also take there toll. I'd guess that over 1/2 of the nuts and bolts on that machine are new. Easier to get a true torque reading on a new bolt. Also, went thru a lot of locktite 242 and a jar of neverseize. I firmly feel that every bolt/nut either has locktite or neverseize.
Ha! That's great John Bud. I love the line "You look in the parts book for the break down, find that what you took off ain't what Ford put on." That cracked me up. Wow, you must have a nack for mechanical stuff. I'd love to be able to do that. The only things I can work on are things that have broken in the past. I learn by necessity, but that job would overwhelm me big time right now. Just need to dig in and get my hands dirty some day. Thanks again for the pictures and stories.
Unfortunately I won't get to do any work on my tractor to fix those trouble spots for quite some time. I'm still trying to patch up the back doors on the house and have to get the FEL installed next week. That alone will hamper some of my work because I'll just HAVE to play with that FEL once I get her installed. :D And we have about 40 calves that need tagging, and branding, not to mention the fence work that I'm discovering. Should be fun in the 100 degree weather we're having!!!
   / How to paint a tractor... #40
Well Spiveman, if you are able to deal with calves, put on an FEL and fix the house you're probably able to fix a tractor. Just takes persistence and a large wrench.
Remember that anytime you get to a problem, there are TBN troupers ready to virtually parachute in to help.
Keep hydrated in the heat!
jb
2024 Bintelli ActivEV Pulse Electric Cart (A59231)
2024 Bintelli...
32" HYD TILT MINI EXCAVATOR BUCKET (A60430)
32" HYD TILT MINI...
Abaco Machines DVL500 Vacuum Lifter (A59230)
Abaco Machines...
Zero Turn Mower (A59231)
Zero Turn Mower...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2019 Jeep Grand Cherokee SUV (A59231)
2019 Jeep Grand...
