Soundguy
Old Timer
- Joined
- Mar 11, 2002
- Messages
- 52,424
- Location
- Central florida
- Tractor
- RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Spiveyman said:Good point on the Darwin awards, I'll be watching the local paper and let you know when he nominates himself. Actually, the guy said he used to paint tractors, but his insurance company shut him down. What's that old line about God watching over fools and little children? Looks like his insurance company probably saved his life.
The tractor is in decent shape, there's a place where the fiberglass front hood is busted, and a crease in the top cover over the engine, and normal wear spots in the tractor like where you put your hand behind the gas cap to get off the tractor. I just like to take care of my stuff, I certainly worked hard enough to be able to afford it, so I want it to reflect my "work ethic" and taking care of my stuff. Thanks!
Those small parts.. if they bother you, can be addressed seperately of the entire unit.
For someone learning painting. have 3 pieces of sheetmetal hanging on a line is a whole lot easier than prepping an entire tractor for painting.
1, that fiberglass nose can be removed and repaired.. or replaced... Fiberglass is EZ to fix... even if it needs a wire frame inside to prop the resin cloth on till it cures.. then sand smooth and contour the fb.. use glaze putty or other filler to get minor surface imperfections. then sand entire nose piece to uniformity... Prime it.. follow directions on whatever paint you use... some require wetsanding.. or scuffing afterwards.. or some have windoes of recoat time.
Then paint it.
same with that dash .. it is seperate of the 2 hood front sections.. though much more labor intensive to remove.. however.. with a roll of tape and a few big sheets of mask paper.. you CAN pain it in place if you take your time.. just prep, prime, paint.
Either of the hood sections are EZ to remove...
If the crease is repairable do so.. IE.. lay the crease down on a wood plant and work it with a dent hammer fromthe other side and a rubbing block if needed... Use a glaze or filler putty if needed to finish off imperfections.. sand, prime, paint..
Douing small tasks like a hood panel or a front nose won't be nearly as bad as the entire job.
Might be a fun learning experience.. and at worst.. you have 3 parts that have marginal paint... which.. sounds like they are no worse off than before... etc.
Even if ya don't paint he hood and dash... do go ahead and fix the nose.. that will be the easiest part.. Even if yuo rattle can prime and paint it afterwards.. it will dress up the entire machine by not having a crushed piece on it.
Still.. as the others have said... she looks like a worker not a parade queen. My worker 7610 has a few warts that i havn't addressed... Like a crumpled left fender courtesy of the previous owner. I just added paint to prevent rust. On a later date.. when the rest of the tractor is ready for paint.. I'll fix the fender.. sheet metal is even easier to repair than fiberglass..
Soundguy
