How to push a BX23 to the limit
   / How to push a BX23 to the limit
ronjhall
Ok, I have 3 pics for you. This one gives you a better point of view.
On this one, you can see what happens when the cylinder comes out.
This one is not a pic but a diagram. /forums/images/graemlins/crazy.gif
(9) is the wire attached on each ends of the arc (4) and it goes all around the chute (eight pattern). Note the "U" bolt (10) in the middle of the wire on the other side of the chute: this bolt is very important to pull the chute on one side or the other. The cylinder (11) push (or pull) the arc and moves it because it's off center.
The mechanism is very strong and you don't want to put your fingers near it when it moves.
Enjoy the pics and the diagram /forums/images/graemlins/grin.gif
   / How to push a BX23 to the limit #24
Now what do you guys say to the "limited" cat1 TPH. Good thing it's "limited", or that thing would be unstoppable /forums/images/graemlins/grin.gif
   / How to push a BX23 to the limit #26
Thank you for taking the time to take all those pics; they're great.
Enjoy your tractor, I know I enjoy mine...
   / How to push a BX23 to the limit #27
Stef said:
Volfandt
Exactly, BX23 has an outlet behind for the back hoe.
The thing is... you have the outlet... but you need a remote valve to operate it. /forums/images/graemlins/mad.gif So you have to put your hand in your pocket again. But if you decide to sell the tractor, you can keep the valve. /forums/images/graemlins/grin.gif
Stef,you did a great job on your setup. I would like to mount a rear hydraulic remote on my BX23 as you did. Can you tell me what brand of valve you used?
Installed by my dealer... brand: Kubota.
   / How to push a BX23 to the limit #29
Stef said:
Ouffff... the last one
Is there a more efficient way to post photos? /forums/images/graemlins/confused.gif
Hey Steph when you go to the manage your attachments you can do multiple attachments to the same posting. That way you will be able to put in as many pictures as you desire on the single posting
Example
I know but two years ago with the other software used for this forum it wasn't possible to add multiple attachments to the same post. As you can see, that thread hasn't been started yesterday.
2018 Nissan Versa Sedan (A59231)
2018 Nissan Versa...
2023 WRANGLER 5500T ARTICULATED WHEEL LOADER (A58214)
2023 WRANGLER...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
2016 FORD TRANSIT 350 HIGH ROOF VAN (A59575)
2016 FORD TRANSIT...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A56436)
Gleaner N630 Corn...
2022 CATERPILLAR 242D3 SKID STEER (A60429)
2022 CATERPILLAR...
