California
Super Star Member
- Joined
- Jan 22, 2004
- Messages
- 16,664
- Location
- An hour north of San Francisco
- Tractor
- Yanmar YM240 Yanmar YM186D
The instructions say drain the tank then set the tank bladder air pressure 2 psi below the pump cut-in pressure.
But I need this clarified. The control is set to start at 40 psi, cut off at 60 psi. I found the tank pressure same as the water pressure at the well, 55psi, a few minutes after the pump had ended its run.
Do I simply turn off the pump, bleed the system at the lowest faucet, then get the tank pressure down (or up) to 38 psi? Or should I do something entirely different.
Advice needed!
Advice needed!
