How to shorten a trailer?
   / How to shorten a trailer? #11
What a shame to hack up that trailer...
Geez, I would think in CA. there must be a ton of aspiring landscapers & equipment operators that hvae outgrown the trailers & equipment they use.
I would at least look into offering it up for trade on the trailer you are looking to create out of it...
16-20 ft. dbl axle trailers are much more common than what you've got there and could be easily outgrown by a busy business with multiple pieces of equipment to tote around.
After reading all the comments and advice from TBN members and from a trailer dealer. I decided to leave it the way it is. It's a shame to chop up a piece of nice equipment. Too many variables involve and it wasn't as simple as just cutting 4' off the rear. To do it right, it' involves lots of work and not worth the effort. Besides, I could trade for a shorter trailer plus some cash anytime. I have no idea that a 24' triple axle heavy duty 5th wheel flatbed trailer worth more than 3 times of a typical 18' double axle bumper pull utiltiy trailer. It would be unwise to chop it up. Thank you. I knew it was a silly idea:eek: Luckily I have access to this forum and be able to ask a dumb question like this. Here's picture of the trailer with the little dozer on it.
   / How to shorten a trailer? #13
Just wondering about your expertise and what it means to this trailer.
Anyone who would consider tackling a project of this magnatude must know what they are doing, and be proficent at it, or will find out the hard way that they made a major mistake. Considering using a skill saw with an abrasive blade to make these cuts is probably not something you want to try. You will wear out many, many blades, trying to do a job that should require a torch setup, or in todays advanced world, a plasma cutter. ( I prefer the torch)
I built a 27' trailer for a customer, to his spec's. He spec'd it out wrong. After completing the trailer, he asked me to modify it, which is when I started asking serious questions, and he started backpeddling due to the money and expense of the the required modifications.
I finally relented and added six foot to the rear of the trailer, knowing it would not handle right, and had him come over with his truck and pull it empty for a short drive. Unfortunately, it handled fine, so we went back and loaded up a reasonable load compared to what he wanted to haul. Made it almost half a mile before the darn thing started swaying, and he panicked, hitting the brakes. We stopped just shy of connecting trailer to truck in a jacknife situation. He never questioned my judgement again, and I always asked way too many questions to figure out just what he was trying to do in future arrangements.
You situation is the reverse of what he did. You are removing lenght from the rear section of the trailer, behind the axles. This should improve the handling caracteristics' of the trailer, but will add considerable more weight to the tongue, due to not being able to center the weight on the axles. It also will not help in the manuevering of the trailer, since the wheelbase will not be changed, which is what you probably are after. Removal of the front axle is also not going to help that. Removal of the rear axle will shorten your wheelbase, but will decrease the capacity of the trailer.
What you are doing basically is making an arrangement similar to a boat trailer, with the axles nearer the rear of the trailer. Nothing wroing with that, but there is a reason trailers are built the way they are. Most of the weight in a boat is on the rear of the boat,which centers it on the rearward placed axles. Most items hauled on a flatbed trailer aren't like that,in fact most are quite the opposite.
Bottom line, yes this conversion is possible, but unless I miss my guess, your going to need some serious help with it. Running welds vertical and overhead that will be under extreme stress aren't for the average homeowner with a mig gun, and cutting the trailer with a skill saw will soon tell you that your in over your head.
I hope I have added some information to you post without insulting your intelligence. If you are qualified to handle this type of a modification, then you probably already know the answer to your original question.
Respectfully,
David from jax
   / How to shorten a trailer? #14
I posted the last post before I realized you had already decided to leave well enough alone. Good decision!
I started to delete my last post, but realized somebody else might be considering the same thing, so I left it there for future reference.
David from jax
   / How to shorten a trailer? #15
I think you did the right thing not cutting it. If I were you, I would just opt for the longer tractor option
2018 KOMATSU WA320-8 WHEEL LOADER (A60429)
2018 KOMATSU...
2020 DRAGON ESP...
2017 FORD F-450 XL BUCKET TRUCK (A58375)
2017 FORD F-450 XL...
2023 MORBARK WOOD HOG 3400 XT HORIZONTAL GRINDER (A60429)
2023 MORBARK WOOD...
2003 Big Tex 10PI...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
