HST pedals: rocker or separate?
   / HST pedals: rocker or separate? #11
I have a kubota and although I prefer the two pedal setup to the rocker style kubota uses, it's not too big of a deal. The brakes on the other hand, now THAT is a PITA! I still can't understand why Kubota thinks it's a good idea to put the brakes and hst pedal on the same side.
I really do love my Bota, but I'm 99% sure I won't have another HST tractor with the brakes on the same side as the HST pedal.
People told me that I would get used to not using the brake pedals independently....well, I haven't.
I really don't use the brakes for turning simply because of the arrangement of the pedals, would I like to? Heck ya! But I don't.
So in my opinion, the pedal design (1 vs. 2) doesn't make too much of a difference, however I do prefer 2, but moreso the deciding factor for me would be which side the brakes are on. I really miss using the brakes for sharper turning, or when the front tires aren't getting enough traction in the snow to turn.
Unless I find a good deal on a used 5740 with cab, then I'll be switching brands, however, I may never sell my little bota to begin with, because I AM very happy with it otherwise. :D
In the end, it's all personal preference. :thumbsup:
   / HST pedals: rocker or separate? #12
I'm in the camp of the completely happy with the Kubota treadle design, much faster when you need to change directions when using loader.
DevilDog
   / HST pedals: rocker or separate? #13
I have a Kubota 3400 with the treadle pedal and for the most part love it. But as always there is a but. We own a marina and use this tractor extensively for moving boats around our facility. When using the tractor a lot like eight to ten hours a day in spring when the boats are going out and now in the fall when the boats are coming back,,,,,,,, the positioning of my foot on the pedal when backing really stresses the right knee thus causing great pain and swelling during the busy season. You may never use your unit as long at one time as I do but you mention arthritis so you might want to try before you buy to make sure it doesn't bother the old joints
   / HST pedals: rocker or separate? #14
DevilDog
Do you really think it is "much" faster? (and I'm asking honestly, not to be sarcastic or start an argument) But I just don't see how it is all that much faster?
Don't get me wrong, I absolutely love my kubota and I think it is a great tractor. However, I don't see how the treadle pedal makes it any noticeably faster to change direction than two separate pedals.
My neighbor has a JD 4720 with separate pedals (HST) and I've operated that a bit, I never did do a 'test' of the two by timing myself, but I didn't notice that it was any slower. It seems like when you start talking about speed and efficiency with one type over another, it is all theoretical and not real world.
Again, I'm not trying to start an argument, and I do LOVE my tractor :D
but I don't think it's any faster because of the pedal design. Just my opinion :thumbsup:
   / HST pedals: rocker or separate? #15
I have had a kubota and CaseIH CUTs with tredle and 3 JDs with 2 peddle arrangement. For me, the 2 peddle is vastly better. More precise control, very effortless when using it for a long time, and much easier when looking backwards using the 2 peddle. Twisting your body while looking backwards, is much easier with 2 peddle.
   / HST pedals: rocker or separate? #16
Guys, he is not talking about a rocker verse 2 side be side pedals, like you are thinking. If you read his post:
One thing I didn't understand, though, is that the HST pedal is not made to be rocked. I have big feet, and could actually bridge the two pedals - barely. Dealer said that it shouldn't be used that way. I do a lot of delicate loader work, inching back and forth. Seems like having to swap pedals dozens of times would be inconvenient.
He is talking about the HST and the kubota B and BXs.
His currant Kioti has a rocker pedal like Kubota's L series, which you are all thinking of. What he doesn't understand, is why they made it the way they did on the B and BXs. For some reason, Kubota built them with neither 2 pedals side by side, or a rocker like on the Ls. Instead, the forward is up where you would expect it, and the reverse is back where the differential lock would be, with flat deck between them.
I can't find a good picture, but if you go here, click "Features" and them click "Top" over to the right,and then click on the little circle that says "2-Pedal HST Operation", you can see what I am talking about.
chelydra - I can't really help you, we have a M7040 with hydraulic shuttle, but I can't think of any good reason to do it the way they did on the B and BX. Either do two pedals side by side (my personal preference) or the rocker style like on the Ls and your Kioti.
Ed
   / HST pedals: rocker or separate? #17
Thanks Ed! :thumbsup:
... I can't think of any good reason to do it the way they did on the B and BX. Either do two pedals side by side (my personal preference) or the rocker style like on the Ls and your Kioti.
Ed
Thanks for clarifying my ignorant post, Rancher Ed. I didn't even realize that side-by-side pedals are sometimes used for HST. As you correctly point out, my real question was: why have a rocker if you can't rock it? Perhaps heel-down is more intuitive for some people, but it seemed awkward to me, difficult to get such fine control in reverse, and some danger of getting boots stuck in the treadle. (My feet are big enough to bridge both pedals on the Kubotas, but just barely.)
Just one more variable to learn. I didn't even know what the loader level indicator was when I bought my CK20, and now find it vital and use it constantly in every kind of work.
I'm also realizing that usage patterns drive preferences a lot. For example, the dealer was emphatic that the thousand-dollar seat on some models is greatly appreciated. I'm guessing that they mow or till or scrape, which I don't - I'm jumping down every five minutes or so. My first machine was almost an ASV-30 track loader; some rebranded units were being dumped at a great price. But the soft suspension that makes it so attractive to many people made it useless to me; with mainly skid-steer experience previously, I want to use the machine's stiffness to pry out stumps etc. Can easily see where someone going long distances at constant speed would prefer side-by-side or a non-bridging rocker.
All adds to the fun and exploration...
   / HST pedals: rocker or separate? #19
The HST on my old B8200HSTD was kind of a treadle; at least I was able to use it that way with my big feet. I REALLY liked it. In fact, even after two years, I still sometimes will reach with my heel out of habit, even though this newer tractor has side by side pedals. After 12 years, it was just natural.
I will say, i would not want to go back to Kubota's brake pedal layout. Having the HST and the brakes on one side is awful. While I had my Kubota, i didn't think much of it. However, after using this NH TC40D with HST on the right, brakes on the left, I LOVE the steering/cutting brakes, and have found numerous uses for them.
I do miss that treadle operation of the HST. But, as a more informed user, the brakes/pedals on the same side is a horrible design.
   / HST pedals: rocker or separate? #20
We have both and don't have a strong preference one way or the other.
2014 FREIGHTLINER CASCADIA MID ROOF SLEEPER (A54607)
2014 FREIGHTLINER...
2014 Morbark M12R Towable Brush Chipper (A52377)
2014 Morbark M12R...
2013 freightliner Altec D2050-TR Derrick Digger Truck (A52377)
2013 freightliner...
2017 DRAGON 150 BBL ALUMINUM TRAILER (A53843)
2017 DRAGON 150...
7021 (A50322)
7021 (A50322)
2010 CATERPILLAR D6N LGP DOZER (A51406)
2010 CATERPILLAR...
