Buying Advice HST vs Gear Transmission - which would you recommend on this tractor ?
   / HST vs Gear Transmission - which would you recommend on this tractor ? #171
   / HST vs Gear Transmission - which would you recommend on this tractor ? #172
The operator knew he could break traction in low range with both and this is why the test was used in high range to show the transmission limits. I have both types in under 30hp tractors. If I have excellent traction in low range the hydro trans slips and the wheels don't break. The gear tractor always breaks traction on the tires and this is with a 800 pound heavier tractor with little worn tires. Maybe this doesn't play out with larger HP tractors.
Exactly, although I wish Neil did a tug-o-war with exact same size tractor in all ranges, same tires, no ballast and on loose gravel or grass.
   / HST vs Gear Transmission - which would you recommend on this tractor ? #173
I'm pretty sure he will do that. After all the whine going on over on the comments from those who completely missed the point, I'm pretty sure he do that just to have a little bit of peace.
   / HST vs Gear Transmission - which would you recommend on this tractor ? #174
In my opinion from what I have read very few of the tractors written about and owned by posters on this board are worked hard and long with drawbar loads.
The majority are used for mowing and loader work, with some limited rear mounted blade work.
They are not pulling heavy loads considerable distances frequently.
And just to clarify it in my mind untill you are in the lower third of your gearing and scratching for traction you are not pulling hard or
hauling a load that requires going thru your gears to get to speed and downshifting for grades or turns.
The harder a tractor is worked on the drawbar the less desirable the HST becomes and the efficiency of the gears dominate.
Guess I'm one of few and not the majority that pulls hard and at a considerable distance zig zagging up 600' as the crow fly's just trying keep traction in 3rd gear, I always known I was an odd duck...........
L34 getting firewood - YouTube
L34 and Fransgard pto Winch - YouTube
   / HST vs Gear Transmission - which would you recommend on this tractor ? #176
He did the same with the hydro but when he put the petal to full the hydro just whines and whines and whines,,,,,, when he finally let the clutch out all way on gear, the tractor spun the tires in high range and the number show the results. @1:42 the hydro numbers was 1119, @3:12 the gear numbers was 3066 and the tires are spinning........
He was in the high side of 1st when he did spin. And he definitely did jerk the chain, several times when he pulled 3066. And that is close to 100 percent of the machines weighs. I highly doubt it could actually pull that much with r4s on grass. And he couldn’t spin the wheels with the geared tractor in the highest gear. This test proves nothing.
   / HST vs Gear Transmission - which would you recommend on this tractor ? #177
The ultimate test would be to have 2 same make model tractors with only the transmissions being different.
Link them firmly back to back drawbar to drawbar and enjoy a pulling contest!
To make it more interesting vary the surfaces, asphalt, concrete, grass etc and LOL, mud!
Then sit back and take bets.
Oh and weigh each (on calibrated scales) B4 proceeding and add ballast to keep the game fair.
Advertising sponsorship could be sold to to tire manufacturers and fuel people to support the effort.
I have done it with 3 internationals and 3 different transmissions. Gear is the winner!
   / HST vs Gear Transmission - which would you recommend on this tractor ? #178
As others have mentioned he FLOORED the hydro. Thatç—´ the same as putting the gear into high. Of course you won稚 get as much because by flooring it you have put the hydro into not only high range but the highest å*µear?br>
Simple mechanics will say a gear will deliver more power to the wheels but not 3x. More like 1.1x.
A bigger flaw is who uses 35hp CUT and below for heavy ground engaging work in straight lines? The vast majority are sold for uses like mine, multi purpose loader work, shredding, tilling, maybe some small acreage food plots. For those activities the hst shines simply because the convenience far outstrips the need BFF or the last little bit of power. For those who do use smaller tractors for ground engagement, well then yes you壇 want a geared machine - and they are made and sold.
Why not do a video on which is better for specific applications and give some real demonstrations on where is is better? That would be more useful than a dramatically misleading video that compares apples to oranges.
   / HST vs Gear Transmission - which would you recommend on this tractor ? #179
I will say that you seem to ask a lot more from that 3400 than it was ever designed for, yet it keeps on running and begging for more. :thumbsup:
This discussion reminds me of quietly enjoying a cold beverage one night, as two guys argued about which truck would push the most snow; a 3/4 ton 4x4, or a ton dually with power to the rears.
   / HST vs Gear Transmission - which would you recommend on this tractor ? #180
The way I look at if the front stays down when pulling a log then the tractor is not pulling to much, sometimes I think FEL work is harder on my tractor then hauling firewood, I know it is on my front tires. I fill my bucket up with dirt and it feels like I'm lifting a mountain.
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
2001 Chevrolet C6500 Wrecker Tow Truck (A55852)
2001 Chevrolet...
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A55302)
2012 RAM 5500...
Wooden Rocking Chair (A55853)
Wooden Rocking...
2017 PETERBILT 579 DAYCAB (A53843)
2017 PETERBILT 579...
John Deere 4600 (A53317)
John Deere 4600...
