Husqvarna 322T AWD
   / Husqvarna 322T AWD #61
You need a dealer login at Husqvarna support web to find SBs. My dealer shares them with me... I put them on dropbox to make them available, do you mean you can't download them from the dropbox links I provided? Anyone else with problems? It works fine when I try it, even from a different computer.
/Marcus
No, I was not able to download anything.
   / Husqvarna 322T AWD #62
Others have reported no problems, but send me a pm with your email and I will mail them to you.
Br / Marcus
   / Husqvarna 322T AWD #63
I have owned the 322T for about nine months. I have a very hilly yard with several 20 degree hills. Today we received 12" of very heavy and wet snow. The snow thrower worked amazingly well. I had to stop a couple of times to clear the shoot because the snow was packed tight but it was no problem. I run the tires at 8 pounds and did not slip at all. No need for weights or chains like with the old John Deere I used to own.
   / Husqvarna 322T AWD #64
You could be describing my lawn and experiences, too, except I've had my mower for a year and a half. Try painting the chute area with graphite paint. I think it helps to avoid clogs.
   / Husqvarna 322T AWD #65
Glad to hear the R322T performed so well with your snow removal.
Good idea run your tire pressure at 8 psi.
I don't use my R322T much for snow blowing, have a bigger Kubota tractor for that, but
I have a hilly yard too and love how the R322T with the Combi mower deck, can handle the hills compared to my old Wheel Horse riders.
Which mower deck did you get with your R322T ?
   / Husqvarna 322T AWD #66
Hello guys, I just received my brand new R322T AWD and did test mowing and cant reverse if there is any incline behind me... Is this normal? I contacted dealer but they need to call husqvarna with that because they don't have much experience with Raiders. Thanks for any advice.
Max
   / Husqvarna 322T AWD #67
Not being able to back up an incline is not normal.
You may want to check your transmission fluid level.
This is what my transmission fluid level was when I received my brand new R322T from the dealer.
(Fluid level is just below the low line.)
   / Husqvarna 322T AWD #68
I no longer own my R322T, but when I had it I could go forward and reverse up and down very steep hills in my yard.
   / Husqvarna 322T AWD #69
Thanks for advice, will check it when I come back home.
   / Husqvarna 322T AWD #70
I checked and my fluid level is exactly at low level mark. Manual says that it needs to be 10W-50 but it doesn't confirm correct level. I assume that it has to be in the middle?
86"X18' DOUBLE AXLE TRAILER (A58375)
86"X18' DOUBLE...
Loader Bucket (A59228)
UNUSED AGT INDUSTRIAL PD680-PZ HYD DROP HAMMER (A58376)
UNUSED AGT...
406 (A52706)
406 (A52706)
(2) FIRESTONE 18.4R38 DUALS (A58375)
(2) FIRESTONE...
2022 Rayco 1800AWL Articulated Wheel Loader w/ Grapple and Fork Attachments (A56857)
2022 Rayco 1800AWL...
