Husqvarna 322T AWD
   / Husqvarna 322T AWD #51
   / Husqvarna 322T AWD #52
   / Husqvarna 322T AWD #53
I just listed my LIKE NEW R322T for sale to help purchase a full sized tractor to maintain some recently acquired acreage. Will be selling at a great price! PM me with any questions...
   / Husqvarna 322T AWD #54
New topic ... my brand new R322T AWD with 4/10 hour has a transmission leak at the back of the front transmission. I am told I can use it but check before and after use the fluid level in the reservoir.
Husqvarna has a service bulletin about the leak but can't seem to tell me if it is the trans case or just a seal causing the slow drip. Waited 7 weeks to get it from Sweden and used it once. Husq service dealer 60 miles away says they are 2 weeks full up and cannot find any info on the service bulletin. Anybody here know anything about this service bulletin or how to get some answers?
   / Husqvarna 322T AWD #55
I don't know anything about the Service Bulletin that you're speaking of.
If it's a front transmission leak, perhaps Tuff Torq might have some info.
The Front transmission is a KTM 10 L, you might need the serial number of your transmission when you speak to them.
Tuff Torq customer service phone number is
1-866-572-3441
They have been helpful to me in the past on general specification info.
Please keep us informed
Did you by chance check to see if the nuts on the oil lines are not loose.
The oil lines that run from the rear transmission to the front transmission.
One of my new R322T machines was leaking oil, and it was due to one of those oil lines being loose.
Ry2ns I sent you a PM
   / Husqvarna 322T AWD #56
Sorry to hear you have problems with oil leaks. The Service Bulletin B1200049 deals with leaks from lines and fittings on AWD riders built in 2012 (just insufficiently torqued), but your problem seems different.
Anyway here it is : https://www.dropbox.com/s/k0xatfn266c2tdb/HUSB2012_AAen__B1200049.pdf?dl=0
EDIT:
No, you are correct, there are 2 new bulletins out dated 2015-04-27:
B1500024, Creeping AWD transmissions https://www.dropbox.com/s/smo470j7a0qc8z5/HUSB2015_AAen__B1500024.pdf?dl=0
B1500027, Leaking AWD transmissions https://www.dropbox.com/s/zngl1fjh69xn221/HUSB2015_AAen__B1500027.pdf?dl=0
Your transmission needs to be changed under warranty by the dealer. "KTM10 xx has the leaking issue. If the product has this issue the complete transmission should be changed."
/Marcus
   / Husqvarna 322T AWD #57
Some other SBs of interest:
B1400056 Pulley brake https://www.dropbox.com/s/z5fnzze6ufowaa3/HUSB2014_AUenNAen__B1400056.pdf?dl=0
The pulley brake was upgraded to a stronger version. These brakes are only mounted on machines for North America and Australia, the rest of the world seems to survive without them...
B1300072 Adjustment of wheel speed AWD Riders, 2013-10 https://www.dropbox.com/s/2yrhpk6sfwsffpq/HUSB2013_AAen__B1300072.pdf?dl=0
This is the so called "swash" adjustment (front/back transmission speed adjustment). Some dealers and representatives seem to not be up to date or aware of the importance. "Fundamentally, the rear wheels shall ALWAYS rotate at a greater speed than the front wheels. The front wheels may under no circumstances rotate faster than the rear wheels."
/Marcus
   / Husqvarna 322T AWD #58
/Marcus
Hi - I was wondering where you were able to pull up these service bulletins? I tried the links you provided in a couple of your posts, but I can't get them to work.
I have a R322T that I had to replace a transmission after just 8 hours of use. The only dealer close to me are what I like to call "intellicutally challenged" and would like to be able to find out about these types of issues myself.
   / Husqvarna 322T AWD #59
You need a dealer login at Husqvarna support web to find SBs. My dealer shares them with me... I put them on dropbox to make them available, do you mean you can't download them from the dropbox links I provided? Anyone else with problems? It works fine when I try it, even from a different computer.
/Marcus
   / Husqvarna 322T AWD #60
No, I was not able to open any of your links
2019 Ford F-250 Super Duty Crew Cab (A55852)
2019 Ford F-250...
2007 FORD F-150XL TRITON TRUCK (A51406)
2007 FORD F-150XL...
2022 Polaris Ranger 900XP 4x4 Utility Cart (A55853)
2022 Polaris...
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
2016 Ford Expedition SUV (A55853)
2016 Ford...
197711 (A51244)
197711 (A51244)
