Hydraulic top link questions
   / Hydraulic top link questions #21
Derek, my HTL is 21 inches retracted and my stock TL is also 19-1/2 like yours. In my opinion, the HTL is much better if it is shorter than the original TL. I cannot get my boxblade to come completely level or tilt slightly forward because my toplink is just a bit too long. When fully extended with a boxblade, the bottom of the blade rotates so far forward that it will actually rub on the tractor's rear tires. I don't need that much extension. If I were you, I'd certainly go with the shorter toplink. After all, how many implements do you have that require your standard TL to be extended all the way? I think the HTL from CCM looks pretty good. If I had it to do all over again, I'd give them a call.
   / Hydraulic top link questions #22
Gordon, I believe that double pilot check valve is actually a relief valve that works in both retract and extend directions when the cylinder reaches the end of its travel. If you tractor has enough hydraulic pressure to exceed the rating of the cylinder, it could be damaged. The double pilot check valve would relieve the pressure from the pressurized to the return side at some pressure below the cylinder's rated maximum.
   / Hydraulic top link questions #23
Jim, I had the same problem, but was able to get my HTL shortened on both ends to correct the problem.
   / Hydraulic top link questions #24
Rowski, did Green supply you with the eye width info for their cylinder?
On the Tisco cylinder the eye width at the implement end is 1 3/4". Its only 1 1/2" wide @ the tractor end.
According to the Bailey specs their link ends are a full 2" wide.
The Agri-Supply catalog lists a width of 1 7/8" for a Cat 2 replacement ball.
DFB
   / Hydraulic top link questions #25
Gordon, CCI described the valve. here
I use my HTL for everything. I haven't experienced any movement with mine.
I don't know what the the overall width of that HTL is with all the additional plumbing. On my tractor there is a flat steel plate mounted over the top of the rear pto. When I use my tiller the clearance becomes less than 3 " between the Tisco HTL and the guard plate when the tiller buries itself in.
DFB
   / Hydraulic top link questions #26
Rowski,
I might just take you up on that. We'll be up sometime this year. We hadn't really looked in Montgomery, Mostly Jay, but the prices there are high because of the ski slope. Now I hear they want to put in a golf course in Jay. Retirement heaven for some folks but I'm not a golfer, and don't want to pay the inflated prices they're asking.
Thanks,
DaveL
   / Hydraulic top link questions #27
Thanks DFB and Jinman for the info
Gordon
</font><font color="blue" class="small">( Rowski, did Green supply you with the eye width info for their cylinder? )</font>
No. I didn't ask either. I just figured that being cat II that is would be 2" wide. I would grind it down or have it milled down. On the implement end (mine anyway) just use cat II pin in the cat II holes on my implements.
</font><font color="blue" class="small">( On the Tisco cylinder the eye width at the implement end is 1 3/4". Its only 1 1/2" wide @ the tractor end.
The Agri-Supply catalog lists a width of 1 7/8" for a Cat 2 replacement ball. )</font>
I was getting the same confusion in the widths. I found a site (not sure of the name, its bookmarked at my home computer)that sells replacement ends for manual top links and the cat II are 2" wide. Seems confusing but I think they all will work just some may need to be made smaller. /forums/images/graemlins/crazy.gif
Maybe I should trade the NH2120 for new JD TLB110 with the factory top and tilt installed /forums/images/graemlins/tongue.gif Much easier /forums/images/graemlins/grin.gif
You may have posted this before. But I can't find it again.
What is the bore and rod diameter of you HTL. Both for the smaller 6" stroke and the larger 10'' stroke.
This is a stupid question, but I'm buying unseen. Are the HTL that you sell rugged enough for a large class compact/Small ag tractor like mine /forums/images/graemlins/crazy.gif?
   / Hydraulic top link questions #30
Both the Cat 1 hyd. toplinks are 50mm (2")bore and 30mm (1.25") Ramrod
CCI
Made up my mind. I'll go with the shorter HTL 6" stroke.
How do you want to do this, private message, e-mail, or phone?
Look forward to doing business with you.
   / Hydraulic top link questions #32
CCI,
I'm interested in your HTL for my TC40D. I'm doing a lot of box blading and those two remotes that I purchased aren't helping much without an HTL. I've sent a private message as well.
Thanks,
Tom
   / Hydraulic top link questions #33
The # 06003 18-26" Hydraulic unit works best on compact tractors.
   / Hydraulic top link questions #34
Derek,
My M4900 is CAT I. I'll probably have to grind off the 1/4" off the tractor end. The other end will be ok.
I wish now I had waited and bought the HTL with the double pilot valve. It sounds a little safer.
TBone
   / Hydraulic top link questions #35
i dont get what the big deal is about the pilot operated safety valve is, if something blows in your 3pt lift its gona drop just as fast as your toplink blowing would, and besides, you should never get under a raised implement unless its blocked up period. i dont care weather ya have a pilot check valve whatever, ya dont get any part of you under it unless its firmly blocked up. i just made a cat 2 toplink last weekend and it doesnt have a pilot safety valve but i have no worries at all about using it
   / Hydraulic top link questions #36
</font><font color="blue" class="small">( i dont get what the big deal is about the pilot operated safety valve )</font>
If I understand it right, some cylinder seals and/or valves may allow some drift; i.e., it may self adjust when you don't want it to, and the pilot operated safety valve prevents that. And if I'm right, it's like a lot of things; not absolutely necessary but sure a nice feature to have. /forums/images/graemlins/wink.gif
   / Hydraulic top link questions #37
Yeah, you're probably right - the likelihood of something failing back there is probably not greater than another point on the hydraulic system. I don't get under anything either but sometimes, when using the boom pole you have to "steady" something you are loading on a trailor and if it fell suddenly you could get hurt. For the small amount of cost involved I think the pilot valve would have given me a little piece of mind. Too late now anyway - I ordered mine Friday before I saw the one from CCI. The one I ordered is a little heavier cylinder so that makes up some of the difference.
Like Bird said it would also eliminate the drift you might get but my experience with external hydraulic cylinders is that you would get very little if any drift provided everything was in good shape.
TBone
   / Hydraulic top link questions #38
</font><font color="blue" class="small">( Derek, my HTL is 21 inches retracted and my stock TL is also 19-1/2 like yours. In my opinion, the HTL is much better if it is shorter than the original TL. I cannot get my boxblade to come completely level or tilt slightly forward because my toplink is just a bit too long. )</font>
Jinman-
If you have a bit of extra shaft sticking out of your cylinder when fully retracted, you can fix this problem by cutting down the shaft to shorten the link overall. Even better, a lot of the HTL assemblies out there have an 8" range of motion, but get the overall length they need by welding a bracket on to the base of the cylinder, and attaching the ball or "eye" to that. This is how mine was set up). I had to adjust it by cutting off some of the bracket and welding the eye back on.
John Mc
I got my HTL on Friday from CCI. Didn't instatll it till today, actually this early evening. Works well. I didn't get to use very much. Just played with it for about 1/2 hr with the rear blade. Hoses are a bit long but they came as a kit with the HTL. Better to long than to short. I'll have to see, right now they work well being as long as they are. I may make a bracket that hold them. One thing I like about the double pilot valves are that you can disconnect the HTL and the position is held with out having pressure on the couplers. That had never crossed my mind but seems to work well. The idea of being able to adjust the toplink on the fly was a reason for getting it. Another more important reason was that with large implements it is a real pain to adjust the toplink to get the implement level. Usually required adjusting the position control and then turning the toplink a few turns and then doing it again. Not any more /forums/images/graemlins/grin.gif...
Attached are some pictures.
Another view.
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2009 Ford Econoline Wagon Van, 101,671 Miles (A56438)
2009 Ford...
2012 Ram 2500 4x4 Crew Cab Pickup Truck (A59230)
2012 Ram 2500 4x4...
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
2014 GMC Sierra SLT 4x4 Crew Cab Pickup Truck (A59230)
2014 GMC Sierra...
2021 Harley-Davidson FLHP Road King Motorcycle (A59231)
2021...
