I Beam for structural support
/ I Beam for structural support
Just throwing this out there for a comparison. I have an i-beam supporting the second floor of my garage/ shop. It's 32' but has a 4"x4" post a couple of inches in on each end. I had a choice of using a w18x 55 or w21x50. The roof is trusses so the only weight is the load from the second floor. I went with the w21 since it was cheaper, had less deflection under the same load, and the loss of 3" under the beam wasn't an issue for me. I don't remember what weight was used for a floor load.
If you get it wrong then you could be starting all over again (unless you are under it when it fails). If you don't want to deal with an engineer then I oversize it by quite a bit and deal with getting it into place. I was able to use my backhoe but if I couldn't then I was going to use staging on each end and jacks and blocking to get it into place.
what else was done to secure the beam? I could be way off here but I would think the second floor load would be more than my wood framed metal roof? Is the beam exposed? Do u have any pics of the beam installed?
/ I Beam for structural support #43
The 4x4 posts are welded to the i-bean and are sitting on some 3/4" 10x 10 plates mounted to the floor. Because of how I have the second floor mounted to it and the 3/4" flooring nailed and glued down creating a giant square there's no way it can move side to side or front to back. These are the only pictures I have.
thanks for the pics crazyal... nice set up u got there!
/ I Beam for structural support #45
Your still the smartest man in Seattle in my book
Not even close! I'm in the bottom 1%.:eek:
Never had much dealings with Lake Union. Did a small project just east of the hwy 99 bridge on the north end of the lake years ago. Drove 8 or 10 steel pipe piles, and welded beams on them so a straddle
carrier could walk out over the lake and pick up boats and take them back to the beach to be worked on. Now the Seattle water front, or Harbor Island pick anyone of those docks.
/ I Beam for structural support #46
w21x50 does seem a bit overkill. Did you do any calculations or did you just go BIG? How long are the joists on each side of the beam?? (I was going to figure a bit of things, and the beam is actually only carrying half the load of each joist. Thats why I was asking)
His floor may indeed have more load than your roof. The problem with your situation is that in concentrates the roof load onto only TWO points on the beam instead of being evenly distributed like floor joists. ANd without knowing all the variables for sure, Remember I metioned a 16x40 is what you would need. So yea, the beam he used would work in your case also.
/ I Beam for structural support #47
Beamboy didnt list a w21x50 beam so I went down one size to a w21x44, and given a 32' span, that beam would hold a distributed load of 1100lbs PER foot safely:thumbsup:
So now if you 1100lbs and divide by take HALF of the length of each floor joists comming into each side, (since the other half is supported by the walls of the building) that would give you a safe psf rating. Take about 10lbs off of that for the dead load.
/ I Beam for structural support #48
Just guessing, but it looks like your buildign is 28' wide. And if thats the case, the beam is supporting 7' of joist to each side. Total of 14'. So 1100/14 would be about 80psf floor.
I guess it isnt too much overkill. When I did my upstairs, I used 2 w12x26 beams spanning 29'. But they are only supporting 5 ft of joist to each side and not rated for near the floor load.
/ I Beam for structural support #49
Don't be modest.
Two guys with stout step-ladders
His floor may indeed have more load than your roof. The problem with your situation is that in concentrates the roof load onto only TWO points on the beam instead of being evenly distributed like floor joists. ANd without knowing all the variables for sure, Remember I metioned a 16x40 is what you would need. So yea, the beam he used would work in your case also.[/QUOTE]
I can add as many vertical supports as necessary to evenly distribute the roof load couldn't I? Wouldnt that accomplish a similar effect of the floor joists against the beam? As far as the beam supports I planned on doing something comparable to crazyal's set up. Would it help if I upload a pic of my current set up with a drawing of what I plan to do? Its going to be a really rough drawing... but it will depict the basic idea of my approach.
/ I Beam for structural support #51
The steel company I deal with actually has an engineer so I let them figure it out. I probably could have gone with the 44 but their supplier had a 35' w21 50 in stock so they gave me a good price. The footprint is 28'x32' so the floor joists are about 13'6". Neither the front wall or rear walls support any of the floor load so it works out to to about 420 sqf on the i-beam (half of 840). Because it's storage they usually figure higher load ratings than "livable" space since you are more likely to stack boxes and leave less room to walk. I think we went somewhere between 60psf to 80 psf. (70psf x 420sf)/ 30' = 980 lbs per foot. There are no internal walls.
I could have gone smaller and still be fine but it wouldn't have saved much money (since the price is by weight) and since there's a little extra safety factor I can have a bean trolly to move loads (say up to 1/2 ton) around if needed. Around here 80psf for a snow load is not out of the question. Since I have trusses it wasn't an issue but a trip to Lowes and you'll find they have a chart right at the contractors desk for snow loads in your area.
/ I Beam for structural support #52
I can add as many vertical supports as necessary to evenly distribute the roof load couldn't I? Wouldnt that accomplish a similar effect of the floor joists against the beam? As far as the beam supports I planned on doing something comparable to crazyal's set up. Would it help if I upload a pic of my current set up with a drawing of what I plan to do? Its going to be a really rough drawing... but it will depict the basic idea of my approach.[/QUOTE]
Since you don't have trusses I would find out what to use for a snow load so you'll know what to expect on the i-beam. It'll be a little complicated because the side walls will support part of the weight as well as the end walls. Then if your going to have any sort of floor or storage you'll have to add that in. Then I would call around to get prices. I found that the steel companies like to deal in 5' increments (25', 30', 35') so if you need 31' you'll be buying a 35' i-beam. Check to see what they have in stock, that could also mean a savings. Finally you can pour pads for the posts and set the vertical posts and i-beam and then pour your floor for a smoother finish.
here's a couple of rough drawings of my plan.... any suggestions how to improve? As far as snow load goes...I live in North Texas not sure thats a huge concern.... but then again the old saying wait five minutes and the weather will change here in texas comes to mind!
/ I Beam for structural support #54
I've seen people use wood to make a beam like your talking about. I've even seen one that used tension rods as well. You have a lot of room to work with.
the I beam I need will be around 600.00...unless the wood beam is extremely cheap I think the steel I beam would be worth the cost for the additional functionality it offers(trolley w/hoist)
/ I Beam for structural support #56
Hello, Iam looking for a couple opinions... I am planning to upgrade my exsisting pole barn to a shop/workspace, I plan on pouring a slab in the barn (30X30) and I would like to replace the two middle poles that support the ridge with an I beam acoss the barn at 12' high with supports from the I beam to support the ridge. What size I beam would you guys recommend? Is this doable? whats the best way to brace the beam and tie into the building. I would also like to use this beam for an electric hoist that travels the length of the beam. The local steel shop recommended I use 10" 12lb I beam for the 30' free span. Anyone have a clue how much this beam will weigh? Lastly anyone have any suggestions on what to add to the pole barn before I have the slab poured.... Im considering a full bath... is it worth the extra effort and $$? Thanks
In order to do something similar in my barn, I had to use a scissor truss for that length which spanned.... 24 feet or so. You may just want to speak with an engineer about that span and weight bearing.
thanks for the advice gumshu... the local steel shop has a staffed engineer, tomorrow I may see what it would cost to have him come out and make a recommentdation on the best approach.
/ I Beam for structural support #58
After looking at your pictures, you'll definitely have to convert those rafters to a truss system, and need a stout beam to bridge that span. If you do it right the trusses can be separate from the beam, leaving the beam to be nothing more than a trolley track.
so you dont think my drawing on the picture will be sufficient? (assuming the beam is the correct size), starting to sound like this may be more trouble than its worth. Maybe I should just live with two poles as the support.
/ I Beam for structural support #60
Seems I wasnt too far off in my estimation:thumbsup:
shibaura_4043:
The pics definatally help. And adding more vertical posts will certainly help distrubute the roof load. BUT the roof load is still a big unknown. We need to knwo what it was designed for. Until then, we are just speculating. But we can get close but need a little more information.
For starters, I dont remember if you mentioned, but how wide is the building in the direction the rafters are running, what size are the rafters (they look like 2x6??) and how far appart are they spaced.
If we knwo this, we can do a little reverse engineering to see how much load the rafters can handle. Knowing that we can better get an Idea of how much load the roof was designed to handle.
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
New/Unused Outdoor Propane Patio Heater (A65583)
New/Unused Outdoor...
1999 Ford F-150 4x4 Pickup Truck (A59230)
1999 Ford F-150...
Freightliner Tender Truck - Adams Tender (A63688)
Freightliner...
2014 INTERNATIONAL DURASTER 4300 EXT CAB DUMP TRK (A62130)
2014 INTERNATIONAL...
EZ Trail 3400 (A64126)
