I feel like Spencer junior!
   / I feel like Spencer junior! #241
Last summer I used the tractor to dig out the bank on the high side and make a walking area that I could cut with the tractor.
Trouble was a spring appeared and I had two muddy spots that even my little yardman would sink into...
So I decided to dig a trench to catch the water...and feed it into the pond. I had been thinking about doing something like this anyway, to feed water from the pond over to the bank, hoping I might plant some ivy there and get the bank covered with something green that way...
The water in that trench is from the spring coming out of the hillside. Took several hours to fill that much...trench is only about a foot deep, more or less...
   / I feel like Spencer junior! #242
I put in slotted pipe and some crushed stone before covering it with dirt. I hope the stone was a good idea. The thougth is that roots could go down and find water in the loose stone...
   / I feel like Spencer junior! #243
I put a 4" pipe across into the pond. Now water will flow which ever way it needs to to keep the water level in the pipe along the bottom of the bank even with pond level...
   / I feel like Spencer junior! #244
Back at the shed, I wanted to be sure that water that might seep into the old spring house foundation would have a sure way out...
So one more trench was called for...
   / I feel like Spencer junior! #245
Happened to look down at the pond and got a picture of the reason why we don't have as many gold fish in there as we used to...
   / I feel like Spencer junior! #246
As some of you know, a new family member joined us this summer and he required a lot of my attention... /forums/images/graemlins/blush.gif
I don't know why the grass grows so slow around here this year... /forums/images/graemlins/grin.gif
   / I feel like Spencer junior! #247
The B2910 was just perfect size for getting the bucket into the old spring house foundation, which I had to clean out. Was a real mess in there...old pump, mud filled catch basin, and so on...forgot to take a picture at the start...
   / I feel like Spencer junior! #248
View from the inside...
   / I feel like Spencer junior! #249
Drain pipe that runs into that new ditch...
I did not want to dig too close to the walls as there is no footer under them from what I can see...
   / I feel like Spencer junior! #250
Much nicer in there with a crushed stone floor.
I will have to wait until I get a torch to cut off that steel pipe...wish it would have been cast iron!
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
27031 (A51692)
27031 (A51692)
JMR 44" Mini Bucket (A50121)
JMR 44" Mini...
2005 Toyota Tundra Limited Crew Cab Pickup Truck (A51692)
2005 Toyota Tundra...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A52748)
2017 Yale GLC050VX...
2018 Caterpillar 416F2 4x4 Extendahoe Loader Backhoe (A50322)
2018 Caterpillar...
