I hope my story will save someone one day
   / I hope my story will save someone one day #41
I have dropped many trees in my lifetime but it isn't one of my favorite things to do. Too many things can go wrong and very quickly. I much prefer cutting up deadfall or trees that have been pushed down with a dozer. Glad everything is on the mend for you and I hope for a speedy recovery.
At this time I would like thank every one for all your kind words and sympathy. I am very glad all the flowers I got were not at the grave site.
Yes, your right, what should I have done to made this a normal routine.
First, if I had one more person, I would have cut the y's off the trunk before dropping the tree. I do that a lot with extra help and the loader in the right place to protect the bucket man (may have to rethink this part too.)
Second, I should of waited untill more help was here.
I know a few wonder how I got myself into this bad situation and so have I, many, many times. I still feel I did nothing wrong under normal conditions, but this one ended up not being normal. With all do respect, the science of a tree falling to what looked like the heavy side is what should have happened, but it didn't. There is no ryme of reason here. You have all heard the phase, sh_t happens. Believe me, it can and does in the blink of an eye.
As for the next time, I will take EXTRA time to figure out a plan of attack, with at least one other person helping me.
   / I hope my story will save someone one day #43
DDT:
I hope you are recovering well. Your thread reinforced my use of my chainsawing safety hardhat. I got "nicked" by a dead limb hiding in the tree canopy this afternoon. I would have been gashed by the branch or worse if I was less careful. I put another scar on my hardhat, but not on me. Thanks for your safety reminder. Jay
   / I hope my story will save someone one day #44
MikeD74T said:
I'm guessing that a picture of the stump would show an undercut wedge & the hinge cut through....
Good thoughts Mike and a high probability that atleast one of these elements was present in this mishap. BTW, an undercut wedge is what`s known as a Humboldt notch and these can be done very safely if done properly.
I have another theory as to what happened based on this statement
DDT said:
I cut a slope for the tree to fall south, I got about 2" away from the back side and pulled the saw out. My first thought, this is NOT RIGHT, it should have moved before now. The saw kerf was still the same so it was still not even want to come my way. Before I could turn and run the tree clasped the saw kerf and slid down the ramp I cut, then dopped to the ground very fast.
and since DDT has not provided any clarification I`ll tell you how I read his account of what happened. BTW, I`m very sorry that he was hurt and I am not trying to kick the guy while he is down, we all make mistakes.
I can easily read DDT`s account to state that he did not make a notch and a felling, or back cut, but instead attempted to drop the tree using a farmer`s notch which is nothing more than a sloped backcut in the desired direction of fall. The problem with this type of felling of any tree with any weight to it is that it is difficult to make a good hinge which is the primary control over the direction of fall, there is no step created to prevent a kickback of the stem when the hinge does break, with no support under the stem and no hinge the base wants to fall to the ground meaning that you can have a standing tree with no attachment to the ground(no control over direction), and the angled cut makes for a weak structure both within the resultant stump and the falling stem and wedging to control direction becomes impossible.
When DDT stated that the tree "clasped the saw kerf" and "slid down the ramp" I could read this to say that a barberchair(the stem split vertically) was established in the trunk which forced the heel of the stem outward closing the kerf. The leverage against the sloped stump cut within the still standing but now slightly leaning tree would be tremendous, easily enough to break a 2" hinge, now rapidly forcing the tree in an uncontrolled slide down the stump. It happens fast, just as DDT stated.
I`d like to know more about this incident and I`d like to know if I`m even close to the way it really happened.
I appreciate DDT taking the time and effort to post his account so that a good discussion can ensue.
   / I hope my story will save someone one day #45
Norsker, you sound like you have a lot of technical knowledge and experience. Your comments, while a bit over my head (I don't recognize a lot of the terminology), are exactly what I was hoping someone would post to help us understand DDT's accident. Having said that, could you please explain a bit more for those of us who "cut down" trees without knowing the difference between a Humboldt notch and the Humboldt current. Are you aware of any good web tutorials. I don't cut trees bigger than 10 inches often but would like to know more about doing it safely especially as I work in an area with brisk winds and need to control tree fall direction away from roads etc.
It has all ways been a little diffacult for me to explain things though the end of my fingers.
norsker, Your theory is correct. Since I want to learn to (sence I am still here).
Yes this was what I call a larger tree, but it was extreamly top heavy, a elm if it makes any difference.
The 3rd link helped me under stand a lot. Pictures are the best for me. The farmer cut you refer to is what is mostly used around here. OK I screwed up bad but I never new any better either. I guess some ideas were raised is not always correct. I may be red in the face right now but this still should not have happened to me. Why was't this materail in my vo ag class in high school? Never seen it before.
   / I hope my story will save someone one day #49
You see a lot of strange, scary stuff happen with chain saws.
Saw an ad last week during the NFL playoffs showing Brett Favre working around his place in MS or AL using a chain saw in shorts and a T-shirt. I know Brett is tough, but I don't think he's tougher than his saw.
   / I hope my story will save someone one day #50
DDT,
Noone is born knowing all that they will need to know to make it through life unscathed. I appreciate that you shared what happened to you despite the fact that it may cause you some embarrassment, but don`t beat yourself up too badly for not knowing any better. I`ve got alot of hours with a saw in my hands and I`m probably too comfortable with them for my own good but I still feel that chainsaws may be the most dangerous tool a person could buy, both because of the inherent danger of the saw itself and because of the situations that saw use puts a person in, yet no training is required to purchase or operate a saw and infact, proper training is hard to come by.
Thanks Defective for posting those links. There are others on the `net as well but those links convey the general concepts.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
(1) HD 20ft Free Standing Corral Panel (A57453)
(1) HD 20ft Free...
New/Unused YC-26G Sawmill (A57454)
New/Unused YC-26G...
EZ Go TXT Golf Cart (A57453)
EZ Go TXT Golf...
2025 GPS Trailers (A56857)
2025 GPS Trailers...
2011 Ford F-450 Service Truck with Crane, VIN # 1FD0X4GYXBED03383 (A57453)
2011 Ford F-450...
