I need help deciding on new trailer
   / I need help deciding on new trailer
Know idea. To bad u didn't let me know then. Would have saved me a lot of time.
I got the call th trailer is done but we just got hit by a snow storm and pick up is a hour away. Hopefully next week.
I picked up the trailer on Monday got it home no problem however it's covered in salt and snow from the roads I'll post pictures when I have a chance to get it cleaned up weather is really crappy here right now. I'm very pleased with it pulls well it's not overly heavy and I really like the axle ratio. It is much higher to the deck than I anticipated so I'm very glad I opted for the dovetail. Stand up ramps seem very well-made and are easy to operate with the spring assist. No more picking up and moving those heavy ramps. Also it looks like they would be easy to remove if I needed to. I compared the weight from this one to the 14 K I'm borrowing this one ways in about 2400#. Where is the 14 K is north of 4000 pounds.
   / I need help deciding on new trailer #94
Is your new trailer the same length and width as the 14K borrowed one? Can anyone tell me if 1600+ lbs is a typical increase in weight when you go from a 10K trailer to a 14K? Would it be about an equal increase when you go from a 10K to a 12 and then from a 12K to a 14?
It seems a shame that adding over 1600 lbs to the trailer construction only results in 2400 lb increase in capacity, but maybe that's just the way it is.
PS: Good luck with the new trailer, hope it does all your tasks well.
Thank you downslope yes it is the exact same size except for Axel placement. As far as the weight jumps to higher capacities from what I found it just depends on the manufacturer. Mine is technically considered a car hauler not a equipment trailer. I think what that means is different Axel placement and a lighter weight trailer. 10 K was the maximum for this particular trailer it comes standard as a 7K. Most of the equipment trailers I looked at started out at a minimum of 10K and had heavier frames. I did not see many 12 K. I believe that by the time it is built heavy enough to handle 12 K it is almost stout enough to be a 14k so they just go that route.
   / I need help deciding on new trailer #96
I think the 1600# increase sounds reasonable. It's just the way the game is played. Same thing happens when you go to a GN from a BP with a big weight jump. Going from a 14K trailer to a 20K is also a huge jump.
Chris
   / I need help deciding on new trailer #97
Chris
For most manufacturers is a 12K trailer usually just different axles, 6-lug vs 5-lug wheels and maybe 0ne size up on the 15" tires? I thought I read that somewhere.
If that's the case then probably not much added weight for 12K vs 10K and not much more $$ either, maybe $150-200. But when you go from 12 to 14K, now you've got heavy axles with 8-lug 16" truck type wheels and the heavier frame, hitch, ramps, etc to go with it, along with a bigger price jump.
   / I need help deciding on new trailer #98
For most manufacturers is a 12K trailer usually just different axles, 6-lug vs 5-lug wheels and maybe 0ne size up on the 15" tires? I thought I read that somewhere. If that's the case then probably not much added weight for 12K vs 10K and not much more $$ either, maybe $150-200. But when you go from 12 to 14K, now you've got heavy axles with 8-lug 16" truck type wheels and the heavier frame, hitch, ramps, etc to go with it, along with a bigger price jump.
No, it's much more than that.
It's different springs, different axles (still 6lug like 5200# axles but thicker wall materials), 16" wheels vs 15", larger tires, and usually a heavier coupler.
You are right though, the weight is not much more. Maybe 150# tops in most cases.
Chris
The jump up to 12 or 14 k besides Axels & wheels was a 6" heavy channel and heavier cross members vrs the 5" channel with angle cross members I have on the 10 k. I think that is where they pick up most of the weight difference. I didn't compare any tube frames. How ever I did see some manufacturers using 6 " channel on the 10 k. At that point I think the heaviest Axel is the way to go. I wanted a lighter trailer and didn't want aluminum.
Got the trailer all cleaned up finally and loaded up the tractor. Fits much better than the 16 foot landscape trailer I was using. I'm very happy with the ramp choice they don't look like they would be hard to slide off at all if I needed to. I'm going to build some sides for it next and a taller bulkhead.
2009 Kubota RTV1140 (A57149)
2009 Kubota...
Rhino DB150 (A57148)
2016 Dodge Journey SUV (A56859)
2016 Dodge Journey...
Generac 0055640 Diesel Generator (A55272)
Generac 0055640...
68"X17' DOUBLE AXLE TRAILER (A58375)
68"X17' DOUBLE...
1977 Gleaner A630 Corn Head (A56436)
1977 Gleaner A630...
