I Still Hate My Tractor
Status
Not open for further replies.
   / I Still Hate My Tractor #402
Fred, sorry to hear this. I've got the same tractor and overall I'm pleased with it. I've only got about 35 hrs on it so far though. I've mainly ran two implements so far, a 6 ft new Landpride cutter and an older 6 ft extremely heavy duty 35 series box blade. The box blade alone weighs roughly 1300 pounds. Believe me, loaded with dirt, it's a load.
At first, like you, I was disappointed in the power. But I'm figuring out how to use the HST+ to maximize power vs speed. I too live in a hilly terrain area and usually find myself in L gear when working an implement. I've also found when cutting tall grass or climbing hills when cutting tall grass it's best to disengage the throttle auto advancing feature and set the engine RPM to match 540 ish PTO speed. From there you can control the ground speed using the foot control or the cruise control lever. Depending on what I'm doing, for example mowing a large field or grading a long drive, I use the cruise lever. Using my left hand to control the ground speed gives me quite a bit of control, after I got used to it. I still leave Stall Guard activated, so if I hit tall thick grass suddenly, it just slows down.
I mowed the same 25 acre field with this tractor with 105 degree temps outside, air blasting, within 10 minutes of my best time on a 70 hp tractor. Ran the RPMs up manually, used cruise. Worked great. Someone recommended the DK-40. This would be a similar method of running that tractor. I've spent some time on a DK-40 cab too, I like the Kubota.
As to cold starts, I've never tried to start it using one cycle below 25 degrees or so. I always cycle twice below 25 degrees. Old habit starting a Ford 3000 Diesel. But, with two cycles mine fires right up even down around zero.
I have noticed, like you, that operating the FEL while moving can cause the a jerk in motion. I'm assuming that the HST needs hydraulic pressure to operate. Using the loader will cause a sudden drop in pressure. Of course the severity would depend on the pumps ability to recover, which, in this case, depends on RPM. Remember that using the throttle advance and the foot feed basically matches the engine RPM to the current load, nothing more. Other HST equipment I've ran has similar results, unless it has two pumps. With other tractors, like the DK -40 for example, if you match the same conditions you will get similar results. That being said, I think the loader is a bit weak. But it really isn't causing the problem.
Without comparing your tractor to mine, from the seats, it's hard to tell. But, it sounds like you have something wrong. I'd call Kubota directly and see what they say.
   / I Still Hate My Tractor #403
Here we've always set the throttle to 540 PTO rpm's when running the 6' bush hog on the L3940. Would not dream of using the foot throttle with a bush hog, foot pedal for motion control is fine. The hydro gives an awesome amount of control especially when working in tight spots with a bush hog.
   / I Still Hate My Tractor #404
I'm one of those. I don't have anything to contribute, but I'm fascinated by the process. I can't decide if it's like watching a train wreck or a great invention in the works. I guess time will tell.
I don't have the knowledge or tenacity to attempt something like this, and I admire Fred for having both.
Couldn't have said it better myself, Poopy... I mean Pappy!
If you end up destroying the panel, the one for the other side (right) of my 4240 was $156.27 from Messicks. I'm sure the left side is close to that. It comes painted by the way.
Good info. If I only knew if the L5740 LH panel was a direct fit on my L3940 I would simply order a new panel, that's a no brainer.
That Volvo video tore through the Volvo car world about 6 months ago iirc, cool fun. I wouldn't expect to be doing wheelies with my unit but sure WOULD be nice to pull my hill in medium rabbit without dropping the revs so much.
My banjo bolt for the turbo oil line in the block end has a tiny oil hole looks like .060" inch, doesn't look like enough flow to keep a turbo properly lubed. 1.5mm doesn't cut it.
Fred
   / I Still Hate My Tractor #407
I see Fred is using the "pastie" of the VIN world!
Or was it a poor masking job in preparation for a new paint job?
:D
:D
Yeah, hopin not to void the warranty until they see it in action :)
Fred
   / I Still Hate My Tractor #409
Turbo's don't need or want a lot of pressure/volume; if the bearing is flooded it slows the turbine due to drag and can create additional heat.
I would leave the hole size alone. Hydrodynamic lubrication does not require huge amounts of oil.
Too much could be pushed past the seals.
90cummins
   / I Still Hate My Tractor #410
that volvo video looks to start a new off road sport
"Tractor Drifting"
Status
UNUSED WOLVERINE SB-12-72W 72" HDY SCREENING BUCKE (A57193)
UNUSED WOLVERINE...
2019 Harley Davidson (A56859)
2019 Harley...
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A57880)
2014 PETERBILT 384...
2009 IC Corporation PB105 School Bus (A55852)
2009 IC...
2006 Caterpillar 305C CR (A53317)
2006 Caterpillar...
2014 Ford Transit Connect Cargo Van (A55852)
2014 Ford Transit...
