Re: I\'m comparing the BX2200 and the B7500.....
If the
B7510 is the updated version of the
B7500, it is not comparable to the JD2210. The 2210 has the lower ground clearance of the BX, around 7" - 8". The
B7500/7510 is more comparable to the JD 4010/4110, with around a foot of ground clearance. As JWE pointed out, this can make all the difference on uneven terrain. I owned a JD2210 for a year, then got a
B7500 after I found I didn't have enough ground clearance in the woods, which was an expensive learning experience.
A few other BX vs.
B7500 differences that I've noticed (some of these may have changed in the upgraded models), in no particular order:
BX has no tachometer or cruise control,
B7500 has both. The JD2210 has tach, no cruise, and no coolant temp gauge.
BX (also JD2210) has an electric fuel solenoid,
B7500 has a manual fuel valve, which must be used in addition to the key switch when starting or stopping the engine. While the manual valve may be theoretically more reliable, it is definitely less convenient.
The BX (also JD2210) has a completely hydraulic power steering system, while the
B7500 has a power steering gearbox. This means the steering wheel always returns to the same position, a particular benefit when using a spinner knob. /forums/images/graemlins/smile.gif
The
B7500 has adjustable rear wheel spacing, the BX (and JD2210) does not.
The
B7500 has significantly greater front loader lift capacity (and optional backhoe digging force) than the BX. The 2210 loader capacity is closer to the
B7500 lift capacity, with somewhat slower response. The 2210 also has a nicer easily detachable bucket available in several widths.
The BX (and JD2210) offer the choice of turf or "bar turf" tread tires. The
B7500 will accept turf, industrial, or agricultural tread tires (but not all using the same wheel rims).
The
B7500 has individual rear wheel brakes, the BX (and JD2210) do not. To be fair, due to pedal location, the individual braking feature is only useable with the gear transmission version.
The
B7500 (and JD2210) have radiator drain valve, BX has drain plug.
That's all I can think of for now.
