I'm Confused - Joystick, Switch or ???
   / I'm Confused - Joystick, Switch or ???
RollTideRam said:
You say you are getting the Deere diverter. That is what I have. To use it, you flip a rocker switch, then use the joystick. I should not be hard to find a switch to put on your joystick and not use the rocker switch. I don't think you need to get another diverter. Also, you did not mention that you got this, but Deere has a kit to run hoses and quick connects to the bucket/grapple. It plugs into the rear 3rd valve or the rear diverter connects. JC
Yes I am getting the kit to run hoses and quick connects to the bucket/grapple. I guess then all I really need is a Joystick with a switch whether it be a rocker or pushbutton and plug the grapple into the valve operated by the electric diverter.
Now off to serach the web for an afternarket joystick...
   / I'm Confused - Joystick, Switch or ??? #13
Yes, but if you do it that way, you will still loose either the TOP or TILT, and you will be swapping hoses all the time, very inconvenient!
Also remember: when the rocker is activated, the joystick works BOTH rear ports, so you won't be able to raise the loader while closing the grapple. This would case a lot of confusion I think.
   / I'm Confused - Joystick, Switch or ??? #14
Please read my response above in post #13. He will loose all loader control just to open/close the grapple. And if he accidentally moves the joystick for/aft while trying to open/close the grapple, he will operate the hydraulic TOP link. Plus he will be swapping hoses all the time...remember he is getting a TnT setup!
Kennyd,
Thanks for all of your help and the help from others. I re-read all of the posts and I guess to accomplish what I want to do is best accomplished by adding the Fasse or WR valve, both of which will supply the joystick. The WR kit says it is designed to work off of the power beyond but power beyond was not an option on the cab model, I had to go with the electric diverter. I'm sure some people are reading this and just laughing...
   / I'm Confused - Joystick, Switch or ??? #16
Silver_Knight said:
Kennyd,
The diverter is the right choice IMHO.
And, I'm not laughing-you raise all good points and asked great questions.
   / I'm Confused - Joystick, Switch or ??? #17
I'm not saying you don't, because I didn't read all of the post in order, but I hope everyone understands the difference between a electric diverter valve and a electric 3rd function valve. That may be a point of confusion for some reading the post.
OK Shaley,
You just muddied the water! I assume that an electric 3rd function valve is exactly as it sounds...it is a 3rd valve controlled by an electric switch. A diverter will divert flow from the loader to another function therefore disabling the loader until it is not diverting any longer. Is this correct? If so then I could add an electric solenoid to the 3rd valve?
   / I'm Confused - Joystick, Switch or ??? #19
Sorry I gave you some bad advise. I'll continue to use my 3rd valve to open/close my grapple and keep it simple. JC
   / I'm Confused - Joystick, Switch or ??? #20
Silver_Knight said:
OK Shaley,
The "electric 3rd function valve" he spoke of is the one from WR Long that needs the power beyond loop. The diverter valve from WR Long diverts the fluid from the dump/curl circuit to the grapple-THIS is what you want.
2020 INTERNATIONAL TANDEM AXLE SLEEPER (A58017)
2020 INTERNATIONAL...
2024 ArmorLite Aluminum End Dump Trailer (A56438)
2024 ArmorLite...
2008 TRANSCRAFT 48X102 STEEL FLATBED (A58214)
2008 TRANSCRAFT...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
TANK MANIFOLD (A58214)
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A56438)
LMC 2-Row Planter...
