I'm considering having a solar panel electrical system installed.
   / I'm considering having a solar panel electrical system installed. #121
Always keep in mind that the sun delivers 1100W per square meter at the earth surface. Unless you can cant the panel to always stay at a rt angle/normal to the rays it will be difficult to harvest from this potential except during the 4hrs [~10-2] of peak sun. [Photoelectrics go from 10% efficiency upward at escalating cost -- greater demand will ultimately deescalate the cost.] During those 4 you can expect about 100W/M2 of finished electrical power. Following the sun would extend the time, esp on clear days. As tech evolves this will become more economical and capable. For now, staying away from hi tech servo, I would use a conservative yearly figure of 400WHrs/M2/day for finished power. Sizing a collector using that figure factored against your average demand should come close to zeroing your grid intertie meter.
... As you know, I plan to stay away from batteries because the grid is reliable and we have gen backup for any severe interruption. -- also an electric golf cart for micro storage.
larry
Larry,
Storage is the weak link in renewables. I thought long and hard about storage s have many other people. There is a lot of work being done in this area, Super capacitors look very good and we're starting to see them in applications like storing gusts in wind mills but they aren't near the capability of a battery yet. When I was in school they used to tell us that a 1 farad capacitor would be the size of a caboose, now they are half the size of your little finger.
Rob
   / I'm considering having a solar panel electrical system installed. #122
larry
Actually the accepted figure is 1000w/m^2 at sea level, perpendicular to the sun, at high sun.
paul
   / I'm considering having a solar panel electrical system installed. #123
Amazing arent they? To put this in perspective for those who are not familiar -- a Farad is 1 Coulomb per volt. A Coulomb is an amt of charge conveyed by 1Amp flowing for 1 second. So ... a 100F 2 Volt rated capacitor would store 200Coulombs at full charge ... 200A for 1 second. Note the low V tho. The stored energy is only 100 W seconds. [Starting a car takes around 3000 W-Sec] -- Their beauty is that they can deliver and accept energy quickly and efficiently, and for a huge number of cycles. At this point in time they are most suited to parallel power functions where an item [motor or incandescent light] requires a momentary huge inrush current that would cause the powerline/gen/PC/batt-inverter to buckle.
...There is rumor that were due to see a tenfold increase in ultracap capability. That will bring more general and wider use.
larry
   / I'm considering having a solar panel electrical system installed. #124
paul
Not sure why that is accepted, cuz it isnt correct. Perhaps its 1000/sqyard?
   / I'm considering having a solar panel electrical system installed. #125
larry
Tenfold would really make a difference. I have 50F caps as big as my thumb that I'm experimenting with, really neat!
I know that Maxell and Agilent (HP) are working togther with Super Caps.
Rob
   / I'm considering having a solar panel electrical system installed. #127
Amazing arent they? To put this in perspective for those who are not familiar -- a Farad is 1 Coulomb per volt. A Coulomb is an amt of charge conveyed by 1Amp flowing for 1 second. So ... a 100F 2 Volt rated capacitor would store 200Coulombs at full charge ... 200A for 1 second. Note the low V tho. [[[The stored energy is only 100 W seconds.]]] [Starting a car takes around 3000 W-Sec] -- Their beauty is that they can deliver and accept energy quickly and efficiently, and for a huge number of cycles. At this point in time they are most suited to parallel power functions where an item [motor or incandescent light] requires a momentary huge inrush current that would cause the powerline/gen/PC/batt-inverter to buckle.
larry
:eek: Im noting an error I made above in simplifying for the cap voltage dropping during delivery of its energy. I used 1V as the discharge V because 1/2 the charge is delivered above and below that. I lost track and got too many 1/2's mixed in. In actuality, Capacitor Energy = 1/2C x V^2 = 1/2x100F x 4 = 200Joules = 200W-sec ... So that cap has stored twice as much energy as I initially stated.
larry
   / I'm considering having a solar panel electrical system installed. #128
Actually, the accepted figure is 1000w/m^2 at sea level, perpendicular to the sun, at high sun, AT THE EQUATOR.
   / I'm considering having a solar panel electrical system installed. #129
I'm actually waiting for a line item on my Electric bill that goes something like "We couldn't think of a new story, so we are just going to stick you with this extra charge because we can !".
Rgds, D.
:thumbsup: :thumbsup:
The enphase inverters look like a very simple install. They have cables with premade connectors (expensive though) that just snap together at each inverter. It's almost a plug and play system. I think it was something like 18 or 20 inverters (1 inverter per panel) on a 240V 30A circuit. The hardest part of the install is getting the permits.
   / I'm considering having a solar panel electrical system installed. #130
I've been keeping an eye on solar, and don't have a system yet. I just skimmed the thread real quick, but I don't think anyone mentioned this.
Do NOT start by sizing a system according to your current needs. The first step should always be to downsize your current needs. Learn to live with less electricity. Then, size a system accordingly. And when you're looking at payback times, be sure to factor in that your electricity rates will be going up *all* the time.
I've been tracking our usage and bills for about three years. In Nov2010, our bill was $97 for 977kwh, but by Nov2011 our cost had increased so that our bill was $104 for only 900kwh - 7% higher bill for 8% less electricity used. The local power company is going to shutdown three coal powered plants in the next 6-8 years, per the EPA, and construct a big transmission line to replace the lost generating capacity with electricity brought in from another area. That's an unexpected (big) cost for them, which I'm sure will result in a jump in my bill that wouldn't be there if they were able to keep burning coal.
It's easier than you think to live with less. I measured our usage to find out what % of electricity went to what for most things (hard wired stuff is harder to measure). For example, our refrigerator is ~12% of our electricity bill (during winter). We have a desktop computer being used as a server for our home network that is about 7% (90 watts, continuous) and I've purchased a network connected external hard drive to replace it with that uses probably 10% of that. I was going to need to replace the server soon, and the new efficient external drive cost less than a new desktop "server" would. We use wood to heat with during the winter. We're probably going to start using a clothes line instead of the electric dryer. In July2011, our usage was 37% less than July2010. The change? I replaced our 26 year old heat pump (~6 seer?) with a new 18 or 19 seer unit.
I've estimated (through elimination) that our water heater is probably 30-40% of our bill. I've also heard that solar water heating is much more efficient than solar electricity generation. If we go solar, it'll probably be solar water heating first, because of this. Our electric water heater would stay in place to provide hot water on cloudy days. I'd like to find out what our actual costs and benefits would be, so I bought a surplus electric meter off ebay to install right beside the water heater. This will eliminate one guess from my payback equation.
I mentioned before the electric costs going up. Also, the solar costs are going down . So your calculations need to include multiple changing variables over time. How far can I lower my electric usage and still live comfortably? What is the average annual perKWH increase in my electricity bill? How quickly does the cost of the solar equipment go down? If not now, when will these three (or more) variables align to give you your desired payback time frame?
Keith
1266 (A50490)
1266 (A50490)
DMI 3200 Side Dress Bar (A50514)
DMI 3200 Side...
2011 Ford Utility Econoline Van (A50515)
2011 Ford Utility...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
John Deer 625F Grain Platform (A50514)
John Deer 625F...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2019 GENIE...
